I have a 1999 Cutter. The Vacuum pump that operates the A/C heater doors has stopped working. A replacement for the original is $255.00 Questions: #1 Is there a cheeper replacement? #2 Can it be re-built and and if yes, who re-builds it?
John's right about searching junk yards. Many GM cars of the late 80's through the mid 90's,used a vacuum pump for accessories such as yours (high emmision standards,equated low vacuum at idle on these cars). Take a look at any models similar to Pontiac or Chevy J cars, Chevy Celebrity,Pontiac 6000 etc, there vacuum pumps are generally located in the front left fender well,mounted on the underside.Happy hunting
I've also been told that the Buick Grand National used a vacuum pump but they are a rare car indeed. I had the Delco part # for this pump and can't find it. Sorry.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
