Old 01-14-2015, 09:00 PM   #1
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 40
Useful Homebuilt Bike Rack
So Bobbie and I recently decided to take up biking once again. We enjoy the ability to sight see that a couple bicycles give us. The only problem is that we also kayak and the roof of our Suburban is given over to carrying two 16' kayaks. Schlepping two good bikes inside the Sub is out of the question.
We decided that there was enough room inside our 27' Airstream to carry the bikes as long as they could be secured so that they wouldn't thrash around.
We just returned from a short camping trip to Monterrey, CA where we used my new creation, It was easy to make, inexpensive, and worked fine. We even drove over a curvy mountain road on the way home. Everything held together just fine. Here are some pics and rough details on construction.
This carrier has no physical connection to the Airstream; no holes, eye bolts, etc.
The 1/2" plywood base is about 1" less in width than the floor between the fridge and galley. Actual dimensions were more a function of the size of the scrap piece I had left over from a furniture project than much forethought. However, it had to be wide enough, front-to-back, to prevent it from tilting in a rapid stop. We did some heavy braking on the way home and it appears to have resisted tilting just fine. The side-to-side 1" gap allows easy set up and removal while being wide enough to hold things steady side-to-side. I bought the fork mounts at a bicycle shop for about $25 each. The raised 2x4 section allows me to bolt the fork mounts without possibly scratching the floor. I counter sunk 10 screws from the bottom and glued it to the plywood. I considered spacing the fork mounts wide enough apart so both bikes could be secured facing the same way. The problem was that the handle bars--ours are configured like mountain bikes--were then too close to the fridge and cabinets for comfort. Road bikes with narrower handle bars probably could be mounted side-by-side. I also attached a pack of non-slip plastic discs to the bottom surface of the plywood to minimize forward-backward movement. Seems to work.
BTW, the cleats are actually for securing a Yamaha 2 kw generator when underway.
Counting everything, I think this cost me about $70 in materials and maybe two hours construction/fitting time. Carrying the bikes inside also has the advantage of protecting the them from weather when under way.
ID:	230438   Click image for larger version
Those who dance are considered mad
By those who can't hear the music.
Road Geezer is offline   Reply With Quote
Old 01-14-2015, 09:17 PM   #2
1999 28' Excella
New Orleans , Louisiana
We are full-timers and carry 2 mountain bikes inside our trailer. Our trailer configuration is twin beds. Our bikes ride between the beds with moving cloths on each bed. Never been a problem in 2 yrs. Just tilt them over on each bed with the tires touching each other.
badkat is offline   Reply With Quote
Old 01-14-2015, 11:43 PM   #3
Road Geezer
Images: 40
Sounds good! I just hated the idea of cluttering up the back end of our AS with a bikr rack, let alone spending another $300 to $500 on another doodad ...
Old 01-15-2015, 08:37 AM   #4
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I've considered options such as these. Quick question, what do you do with the bikes when you arrive at your destination? Leave them outside locked up?
SCOTTinNJ is offline   Reply With Quote
Old 01-15-2015, 09:29 AM   #5
1999 28' Excella
That's what we have to do. Have toyed with the idea of a storage tent for longer stops. Someone also mentioned using corrosion x on the bikes. Think I will do both of those this year.
Old 01-15-2015, 09:30 AM   #6
1981 31' Excella II
New Market , Alabama
How do you keep the wood plate from sliding around? Many times I will lean a bike up against the couch. Good idea to keep them out of the weather and off the back of the trailer.
Perry
Old 01-15-2015, 10:13 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Ours travel on the Airstream rack in back. I use CorrosionX on the chain and components and a plastic bag over the seats. A greater concern is long-term sun exposure. When in camp we park them on the shaded side of the trailer or under the awnings. We have used a cover for them when parked but that becomes a sail in heavy wind.
The bikes are ten years old, travel this way (outside) 7 months a year and look really good, paint still shiny and chrome is bright. Whether traveling inside or out, a little protection from the elements when parked outside helps.
Doug and Cheryl
Old 01-15-2015, 10:24 AM   #8
2015 23' International
Charleston , South Carolina
That looks great and I already have the fork mounts. Maybe I'm missing something but what are the cleats for?
FollySteve is offline   Reply With Quote
Old 01-15-2015, 10:24 AM   #9
Sorry, generator, just saw it.
Old 01-15-2015, 10:29 AM   #10
With a few discreetly installed eye bolts (maybe at the base of cabinets?) one could lash the bikes down with load straps and then it would be totally secure.
Old 01-15-2015, 12:03 PM   #11
Libertyville , Illinois
I mounted the fork mounts to a 2X4. Since we don't need our dinette when we travel, I put my bikes there. In fact, I can fit 4 bikes on the dinette - two going in either direction. I then cut a piece of PVC pipe to ensure that the spacing is maintained between the two 2X4s. Sorry I am unable to get a picture until spring.
Short563 is offline   Reply With Quote
Old 01-15-2015, 12:32 PM   #12
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Can you get to the bath area with the bikes in the way or do you have to remove one or both of them?
Kelvin
Old 01-15-2015, 01:59 PM   #13
mefly2's Avatar
2012 20' Flying Cloud
2013 25' FB Eddie Bauer
2014 25' FB Eddie Bauer
Small Town , *** Big Sky Country ***
...and, we just lash them to the Airstream D-rings on the floor ... LOL If we didn't have the EB, we would simply install suitable anchor points in unobtrusive spots and secure our bikes in that manner - with soft perlon rope. Motorcycle "soft" ties work very efficiently!
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 01-15-2015, 04:23 PM   #14
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I used a setup like that for several years in our 20'. My version uses less lumber so it's easier to stow, but lacks the generator storage. It fits like a jigsaw puzzle and doesn't move at all.
ID:	230492   Click image for larger version
2012 Dodge Durango Hemi/AWD
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 07:21 AM
Bike rack on a Suburbban Les Gilliam Our Community 2 04-06-2003 08:25 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 11:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 11:57 AM
