Old 02-14-2011, 01:45 PM   #1
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
Two Front Steer Axles
I was recently in Peru and seen this Bus, The first thing I thought was "That would make a great RV!"
ID:	122284   Click image for larger version
myfirstrv is offline   Reply With Quote
Old 02-14-2011, 09:31 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Dual Steer
Not IMHO. Although these units can be ordered (in Canada) they are not a great highway unit, especially in a 3 axle combination. Dual steer combines with tandam or triple drives serve the purpose where a lot of weight is carried, but with a single drive, you have too much weight up front. This creates a real problem on ice and wet or mud roads, as you loose the steer, even with the best anti-lock brakes, in sudden stops.
WORKS LIKE AN ARROW. HEAVY END GOES WHERE THE MOMENTUM CARRIES IT.
Now this I would go for, but you would need to be carrying all your gold bars to justify it.
Dave
Old 02-14-2011, 09:59 PM   #3
masseyfarm's Avatar
Images: 56
Wbcci moho issue
Dave
This unit with a LAND YACHT CLIPPER decal might just solve the issue for those who need a new motorhome. Imagine how many slides, freezers, barbaq's, etc. you could get into this!
Dave
Old 02-15-2011, 10:16 AM   #4
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Yes, More is Better ? is always a Myth
and an expensive myth
John H. is offline   Reply With Quote
Old 02-24-2011, 07:21 PM   #5
myfirstrv's Avatar
Vermilion , Ohio
Well it looks cool
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 03:42 PM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
What is this part? (front end shelf) SpaceEgg General Interior Topics 2 01-09-2011 05:11 PM
