Old 08-14-2006, 10:03 AM   #1
Chuckles's Avatar
Iwerne Minster , Dorset. UK
Arrow TV Antenna on Classic Roof
I have one of these folding antennas on the 310, that is operated from a single up-down switch. From what I gather they were common on late 70's and early 80's motor homes.
ID:	24670 Click image for larger version
Does any one know where I can purchase the spares, in particular the gears as mine have broken beyond repair or even pattern making. I also need to convert to 75 ohm impedance/cable. Any thoughts on that.
It seems to work OK otherwise apart from dirt on the switch.
I would be interested in buying a second hand Antenna if some one has thrown theirs out.
There will be the trouble of shipping it to the UK,although there are contacts in the USA That have offered to help in the shipping department.
Thank you in advance
Chuck
Dorset UK
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 08-14-2006, 10:42 AM   #2
1989 37' Airstream 370
Hastings , Minnesota
Antenna
The antenna that you have is a Braund. They are made in Michigan. The ones that go up and down no longer exist.
You can buy a manual one that bolts right on. You also can buy a gear kit for approx. $9.00 at any Camping World store.
Pat370
Pat370 is offline   Reply With Quote
Old 08-14-2006, 02:56 PM   #3
Chuckles's Avatar
Thank you PAT 370, I did look up Camping Worlds web site and could not find any reference, also they are not very helpful when ordering from overseas.
I did find the Braund site though, and written to them so keeping fingers crossed....
At least now I know what brand (Braund) it is - sorry couldn't resist that!
Chuck
Dorset UK
Old 08-15-2006, 12:52 PM   #4
noiva's Avatar
Chesapeake , Virginia
Images: 46
Chuckles, In addition, the model is called a Skyliner, and you just may find a set of gears still available at one of your local (hopefully) RV parts stores. They were excellent antennas, but the gears will eventually break no matter how careful you are. There is supposed to be a cover over the gears, and that helps a little. Be sure to put lots of silicone dielectric paste on the gears if you get another set. You'll need a set of snap ring pliers to remove the antenna support posts to replace the gears. Buy all the sets they have - if you plan on keeping the antenna . Have you tried Camping World's Technical Service department? They are usually very helpful with things like this. 1-800-622-6264.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 08-15-2006, 03:12 PM   #5
Chuckles's Avatar
Tim, thanks for that. I will try Camping world again and see what happens.
I did get a reply from the Braund site (service@barkermfg.com) and they say they have.... "THE DELRIN GEAR BUT DO NOT HAVE DRIVE GEAR..." As I see no reference to gear names in the airstream manual I have asked for an explanation and also if the drive gear will be available later.
I will keep you all posted on that one.
PS Just rang Camping world - No-Go; nothing left in stock
Chuck
Dorset UK
Old 08-15-2006, 03:16 PM   #6
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Weren't these electric antennas also available on the first Excella 500's? I thought I saw it as an option in my 1971 Excella brochure. I'm in Arizona right now, so I don't have access to my sales brochures.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 08-15-2006, 03:27 PM   #7
Alden Miller's Avatar
1993 34' Excella
, Maryland
I'm interested also!
Chuck, let me know what you find out. I am interested in repairing my antenna also. Mine will go up and down but once it rotates past a certain point it won't return without a trip up onto the roof.
I looked at the gears and one of them seems to be missing a tooth. I can't remember which one without going back up on the roof right now but I'd be interested to hear what you find out.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 08-15-2006, 03:30 PM   #8
Chuckles, you will see that I live a couple of hours from you, but keep my Airstream in the USA, where the roads are wide, and the State Park campgrounds are wonderful, (and all the kids are above average! - don't you listen to Prairie Home Companion??). Both parts of the Skyliner gears come as a kit. I purchased my spare kit for about £5 from http://www.marksrv.com/antenna.htm
They will post items very promptly, in my experience.
It would be worth buying an extra kit as a spare. The only tricky part of the replacement is withdrawing the small steel rod that passes through the gear, provided, as recommended above, you have some circlip pliers.
If the remainder of the antenna is in poor condition from corrosion and UV degradation, you might consider replacing it with the ubiquitous "batwing" antenna. The Skyliners are no longer available.
Alden, I hope this is of assistance to you.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-15-2006, 03:33 PM   #9
1993 34' Excella
, Maryland
Hold on...
A google search turned up a place that might have the parts.
Says they have replacement gears for about $9.00.
-Alden
Old 08-15-2006, 05:59 PM   #10
noiva's Avatar
Images: 46
Chuckles,
Looks like you have some good leads. Sorry about C.W., but that part hasn't been made in a while. Many RV parts places, usually dealerships with a parts department, carry the gear kits. Should be still some around. I'll run up to my local place tomorrow, and get one if they have any left - IF that's something you'd like for me to do. Then I'll let you know and we can PM to make arrangements to get it to you, if you like. The two gears are generally called a "worm gear" - which is a straight tubular gear that runs on the base. As Nick said, the metal pin in that one can be a little tricky, but I've replaced it enough that I'm sure you can do the same. The other gear is usually called the "lift gear" and is a half-circle type affair that raises and lowers the antenna when you turn the worm gear from inside the MoHo. I have no idea which gear they're calling a DELRIN, but there aren't but 2 gears, so it really doesn't matter. By the way, sooner or later the gears chip like Alden described. I've never found a way to stop that in the 23 years I've had rigs with that antenna.
Hope this helps.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-15-2006, 06:25 PM   #11
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
I have the same ant in my 73 Sov. It is manual.
trevisgardne is offline   Reply With Quote
Old 08-15-2006, 06:31 PM   #12
noiva's Avatar
Images: 46
Yeh, I'm not sure what some posts mean by electric, unless they're talking about the antenna booster on the wall inside. I've never seen a Skyliner with an electric lift, if that's what folks are referring to, but I guess anything's possible.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-15-2006, 08:24 PM   #13
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I got it
I have a complete antenna and the gearing mechanism at the base. I will send it to you if you need it. Anyone listening in....I need a complete antenna assembly that mounts on the front of the older Airstreams. Raises vertically then folds out. Controled from the interior.
RC
Old 08-15-2006, 08:38 PM   #14
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
One of the first things I did after bringing Chummy home was to take of the TV antenna and it still sits here. I just hate the way they look and never watch TV. Chuckles, Brit TV is awful why do you want a TV antenna?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
TV Antenna lead fdx753 Audio, Video & TV 14 04-27-2004 08:45 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
