The owners manual is the best place to look for this type of information. I will tell you this, an MG on a trailer will more than likely not weigh anymore than ay other toad that people are pulling. Be sure that the trailer you are going to use has brakes and a proper breakaway setup and you should be fine.
Most of the Airstream P30 chassis motorhomes have an upper limit in the 2000-3000 LB range. The only thing that I was able to find that would stay below the 2000 LB number was a Geo Metro.
Most people tow Saturns and the like and they stary in the 2400 LB range.
The biggest issue is the braking. You need to have enough stopping power on the MH to bring the whole thing to a stop with a trailer or toad brake failure. With proper brakes on the trialre the sales guy is right, you won't even know it is there.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
