Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 03-07-2003, 04:36 PM   #1
LKappenman
Finally Retired
Profile:  , Washington
Towing a Jeep
We have all the info we need to tow the wrangler, I just finished the hitch assembly now for the wiring. I have towed with the Jeep and have all the appropiate connections now I want to TOW the Jeep has anyone done that wiring to a tag along? Is there a place I can look at a diagram? Any help would be appreciated thenks Dave.
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Old 09-13-2003, 12:36 PM   #2
MarkD
Profile:
I tow a Jeep Wrangler also. I bought a nice looking pair of tail lights from an auto parts store for about $20 each and mounted them on top of the rear bumper. There was just enough room so that the rear door did not hit them. I then ran wiring through the frame of the jeep to the front, which I plug into the motorhome. This way I do not use the jeep tail lights at all for towing. My front bumper is attached to a round tubular bar. This is where I store the wiring when I am not towing. There can be complications if you try to use the vehicle tail lights when towing. I think it is easier to simply add an extra pair of lights. The extra tail lights actually look good on the jeep. Adding an extra pair of tail lights to a car would probably look odd. If you want to spend more than $20 you can buy really nice chromed tail lights that are sold for motorcycles and mount them on the real bumper.
MarkD is offline   Reply With Quote
Old 09-13-2003, 02:38 PM   #3
Fun-Lovin
Profile:
Here is a very simple solution. Run a 4 conductor wire to the back of your jeep to where the 4 flat plug is for towing. Connect it to the jeeps plug (no splicing or taping into the jeeps wiring harness. It will feed to the jeeps lights as would it feed from your jeep to a trailer. Good thing is you can take this wire and rolll it up and put away when you dont need or leave it perminantly attached to the jeep.
Other option is to get a set of those magnetic lights, again no mounting or wiring required to the jeep.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 09-13-2003, 05:21 PM   #4
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 215
Check the "flat plug" circuitry
Depending on the OEM wiring circuit, the flat plug idea may or may not work.
On some autos three or four diodes will be required.
They run about 10 bucks apiece.
If the extra set of running lights is acceptable, or if there is a place to mount temporary lights dedicated to towing, then a separate light system is, IMHO, is the way to go.
"Looks good, doesn't cost much, lasts a long time."
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 09-19-2003, 08:33 PM   #5
k5cad
Profile:
Independent lights without bolt on reflectors
Dave,
My last Toad was a Jeep Cherokee. There was enough room inside the Jeep's tail light housing to drill a hole and install an extra bulb socket. Make sure they are behind the red lens. Simply wire them directly to a 4 pin flat plug up front completely isolated from the vehicle's wiring. It worked for me better than isolating the vehicle's bulbs with diodes which often short out or open up. And there are no extra lamp housings to bolt on.
Steele
Ebert Steele
k5cad is offline   Reply With Quote
Towing with a Jeep? Roger and Nancy Tow Vehicles 11 08-19-2003 09:47 AM
Airbags and Towing with Car mcostanzo Tow Vehicles 0 07-02-2003 03:40 PM
Towing A Jeep Behind 39' As Deisel TENX53 General Motorhome Topics 2 06-17-2003 09:55 AM
Another towing question ipso_facto Our Community 27 03-22-2003 08:06 PM
5.9L Jeep to pull 29' Ambassador? MiamiMike Our Community 5 03-14-2003 02:35 PM
