Old 07-12-2010, 06:13 AM   #1
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Towing a car with a dolly... tighten those straps and check them!
Those of you who use a dolly, I learned a valuable lesson yesterday... Make sure your straps are tight tight tight!
We got into an accident with the camper and dolly, and the car stayed where it belonged, and took only minor damage. The dolly is probably a write-off: the tray was bent into a slight "U" shape, and the tongue would have to be replaced, and there's some electrical problem because the lights stopped working. I've hated that dolly over the years, but right now I'm very glad it protected the car so well.
However, the tow truck driver told us that frequently during accidents the cars come off the dollies and end up under the camper. So, make those straps tight. Of course that might still happen if you hit someone at a higher speed but try to be safe as much as you can.
I always tightened the straps quite a lot, and I worried about damaging the tire or wheel (though I never have), but after yesterday I'm glad I did that.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-25-2010, 07:32 PM   #2
1995 36' Classic 36
Orangevale , California
Curious about your towing. Is the weight above what the mfg specs it at? Aside from keeping miles off the vehicle, why sue a dolly? Isn't the added weight of it an issue?
Hope you and your B is okay.
Pomfritz is offline   Reply With Quote
Old 07-30-2010, 08:30 AM   #3
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
We use a dolly for several reasons.
1. Each time we trade vehicles we do not have the expense of setting the new one up to tow.
2. I think its just as quick to load up and go as the tow bars.
3. We can tow any of our vehicles with it. (I have even towed my corvette.)
3. It has its own surge brakes.
4. With the big overhang of our 345 going through dips and swales the dolly does not stress the motorhome frame. The tow bars are short enough that the motorhome can actually try to lift the car off the ground.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 08-04-2010, 06:25 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Thanks. The B van is being repaired now... actually he thought they'd finish today, so hopefully we can get it back this weekend.
Which weight? The dolly is spec'd to handle SUVs, so my 3,000 lb Cougar is definitely not a problem. The Impala's curb weight is a bit more - 3,400 lbs - but it's still not a problem.
The camper plus dolly plus towed vehicle should all come in under 15,000 lbs, which is the GCVW of the camper. (9,000 for the camper, 500 lbs for the dolly, and 3000 for the Cougar gives us nice headroom for supplies, people, etc.) The dolly only weighs 500 lbs, though it feels like a lot more than that when I have to manually push it back up the driveway.
As for towing four-down, there were several reasons I didn't want to do it, some of which are similar to cooperhawk's:
1. It's just as expensive as a dolly... without brakes. I priced them out and found that a dolly was cheaper once you figured in the cost of brakes (mine has electric brakes).
2. You have to get an ugly, un-aerodynamic hitch for the front of your car. This was especially a problem for my Cougar (the vehicle I usually took with me on trips), because the hitches aren't even available, but even if they were I wouldn't want that on the front of my car. I didn't want it on my Impala either. I'm a bit of a car enthusiast and seeing those things on my car, even just the brackets, would have been pretty annoying.
3. Said tow bar bracket can only be used with one car - want to tow something else? You have to buy a new bracket for several hundred dollars, if one is even available. Whereas with the dolly I can tow pretty much any car; I've towed both my Cougar and my Impala, as well as my wife's Saturn (we met well after I had the camper and dolly setup ).
4. Some cars (not my Cougar since it's a stick, but the Impala falls into this category; not sure about the wife's Saturn) require a halfshaft disconnect, so even more money.
In my case I already had the cars before I bought the camper, and I don't want to be limited to the few cars that can be flat towed without the halfshaft disconnects. And it's a good thing I didn't limit myself to towing just one car - there have been several situations where it made sense to tow a car other than the Cougar.
There are advantages to four-down towing - the dolly has been a lot of headaches for me over the years (see my website), especially with loading and unloading, and that all would go away with four-down.
We've since decided to junk the dolly. If anyone needs a spare tire for a Stehl tow dolly, we have one, never used, will sell cheap. Comes with two free caps for the grease fittings - we'd lost one and ordered two new ones before the last trip. Just PM me.
We're not going to replace the dolly. Instead, we'll either rent a car at our destination, or my wife will drive a car separately. The long-term plan is to replace the B-van with an Airstream trailer in a year or two anyway, so we'll just deal without a dolly until then. I will say I'm really looking forward to not towing a car on the trip next week, but I'm going to miss having my Cougar on vacation.
Old 10-04-2010, 12:58 PM   #5
frankandsue's Avatar
Long Beach , Mississippi
I was just going to post about towing. We have a 36 ft Airstream Land Yacht Clipper Diesel. I have a Scion TC. Had it before the motorhome so just wish to tow it on a dolly. It is pretty low profile and not very heavy. Any advice on which kind of dolly to get, what type of brake is easiest to use. We see something called American Car Dolly that folds to a smaller footprint for storage. Would there ever be an issue of dragging the rear of a low profile vehicle when towing on a dolly?
Frank & Sue
frankandsue is offline   Reply With Quote
Old 10-05-2010, 08:13 AM   #6
The Hawk's Lair
cooperhawk's Avatar
Our dolly is a "Demco", made in Iowa and we have been very satisfied with it. The overhang is no problem with the dolly as the tongue is long enough to compensate for it. The surge brakes work very well and you hardly know you are towing a vehicle.
AKA THE GUNNER
VFW, LEGION, NRA
Old 10-05-2010, 09:57 AM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I've never had a problem with the Cougar, and it sits fairly low. Even after I lowered it an inch I didn't have any problems scraping.
But, yeah, buy a good dolly. More money, yes, but it'll save in the long run if my experience is any indicator.
Old 02-05-2011, 09:57 AM   #8
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 57
Dolly Rules
Here is a reminder to unload the car before disconnecting the dolly from the back of the motorhome. The dolly shot forward right thru the f/g bumper.
Dave
<a href="W0015 pictures from road trips photos on webshots src="http://thumb15.webshots.net/t/71/71/...5tkveRv_th.jpg" alt="W0015"></a>
Old 02-23-2011, 09:51 AM   #9
audiv8q's Avatar
1986 34.5' Airstream 345
Longview , Washington
Send a message via MSN to audiv8q Send a message via Yahoo to audiv8q Send a message via Skype™ to audiv8q
So - here's our scenario:
We're buying a 345, and had at first been planning to tow the Jeep Wrangler TJ on a tow bar that's already mounted to the Jeep now. The Jeep sits higher than many "cars", but after reading that, I am worried about the "lifting off the ground" part. Any comments?
Now - I said "had at first been"' - my new scheme is to find a 31' - 34' Airstream Trailer that is in need of restoration, and convert it to a "toy hauler", by putting a divider wall in front of the wheel wells, build a bedroom in the front, and move the bathroom, eliminating the kitchen which we don't need to duplicate (since we have one in the 345), and driving the Jeep in from the back of the trailer, and parking it between the wheel wells over the axles.
Yes, I know I'll have to do some major reconfiguring to the rear. I plan to cut the rear off the trailer where it begins to round - then cut the rear shell in half, and somehow hinge the 2 pieces to make a "barn-door" style opening to drive the Jeep into. The only thing that will give away the modification is the missing rear window - or possibly the presence of 2 small rear windows instead of the one big one.
So my further question is this: With the "big overhang" of the 345, how will it handle pulling a 32' Airstream trailer? Will I run into similar problems?
Thanks for your help - we're "not yet brand new Airstreamers", so any help is appreciated.
Oh - by the way - I also need to locate a replacement spare tire cover for the 345. It's in really good shape, with the exception of 3 items:
Spare tire cover door is missing, shroud for the rear AC is missing, and the backup monitor is missing.
audiv8q is offline   Reply With Quote
Old 02-23-2011, 09:56 AM   #10
audiv8q's Avatar
The Jeep can be towed 4-down, but requires a driveshaft disconnect for front-up dolly towing - so I am stuck with either 4-down, or full trailering - and in that case, I may as well buy an old Airstream 31' and make my mods as stated above - which will also give us the extra bedroom, so the wife and I don't need to worry about "'sounds in the night" with the kiddies present!
Old 02-23-2011, 10:06 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think more than the reconfiguration to the rear to get some sort of a door, you'd have to build an entire custom heavy-duty frame to be able to support that kind of weight. You're talking about carrying a vehicle that weighs close to 50% of the rated max gross weight of the trailer you propose to modify, and probably only about 1000 lb. of that original rated gross was intended to be cargo and water.
Old 02-23-2011, 10:10 AM   #12
masseyfarm's Avatar
Images: 57
Toad
I don't understand why you would have to disconnect the drive with front up towing. Please explain?
Below is a link with lots of up to date info.
http://www.motorhomemagazine.com/ima...yGuide2010.pdf
Dave
Old 02-23-2011, 11:16 AM   #13
1972 21' Globetrotter
nc , North Carolina
Dave
me too, never seen that, have to before.
rock60 is offline   Reply With Quote
Old 02-23-2011, 12:29 PM   #14
DKB_SATX's Avatar
1976 Argosy 28
Dave
The article you link is all about 4-down towing.
If you're front-up towing a vehicle that's FWD or is RWD and approved to be towed and you follow the sometimes-arcane procedures described in the article you linked, things should be fine.
Where you run into trouble is with 4WD/AWD vehicles on a tow dolly. The center differential or transfer case usually isn't designed to have only one set of wheels turning for long periods of time, with the other set held stationary. That's when driveshafts need to be disconnected.
Car Dolly / Wiring Question Darel Towing, Tow Vehicles & Hitches 7 04-02-2008 07:20 AM
towing with tow dolly tandemfish General Motorhome Topics 17 10-16-2007 07:49 AM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 04:46 PM
Stehl Car Tow Dolly n5wc Towing, Tow Vehicles & Hitches 0 01-20-2006 08:22 PM
Towing Dolly Clyde Gartman Airstream Motorhome Forums 0 04-18-2003 02:09 PM
