Old 04-12-2018, 04:24 PM   #1
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Tow Dolly
Is it the total weight of the vehicle or just the front axle weight when using a tow dolly?
Mjgman is offline   Reply With Quote
Old 04-12-2018, 04:35 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Both, and neither.
The tongue weight is next to nothing because the vehicle's front wheels are directly between the tow dolly wheels, and only the actual weight of the dolly's tongue is applied to the receiver. The car's front axle weight is applied to the dolly's axle weight, not the tongue weight.
But for horizontal pull, the entire weight of the towed vehicle, plus the weight of the tow dolly, is applied to the hitch.
So in the case of an Interstate EXT, for example, with a towing capacity of 500lb. tongue weight and 5000 pounds gross trailer weight rating, one wouldn't come anywhere near the 500 pounds tongue weight, but could very easily exceed the 5000 pounds GTWR if the towed car has a GVRW close to 5000 pounds and the weight of the tow dolly puts it over.
If there's any doubt, weigh the towed vehicle before putting it on the dolly and go by actual weight rather than gross weight rating.
Cats and ultraleather Airstream upholstery don't mix!
Old 04-12-2018, 05:12 PM   #3
Mjgman's Avatar
Bradenton , Florida
I was meaning if the tow dolly is rated to tow 4500lbs is that the total weight the vehicle can be, or is it just what the front axle weight is?
Old 04-13-2018, 01:41 AM   #4
Toad GVWR. The dolly is rated by what the dolly's towbar can pull.
Battery-op TOW DOLLY Recommendation? TGadaire Towing, Tow Vehicles & Hitches 5 11-14-2012 10:57 PM
Hitch tow dolly Brian Casson Tow Vehicles 0 11-02-2010 09:53 AM
tow trolley or dolly katpateb Towing, Tow Vehicles & Hitches 11 07-22-2009 10:00 PM
towing with tow dolly tandemfish General Motorhome Topics 17 10-16-2007 07:49 AM
Stehl Car Tow Dolly n5wc Towing, Tow Vehicles & Hitches 0 01-20-2006 08:22 PM
