Old 01-08-2010, 08:34 PM   #1
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Toad breakaway signal
From what I have checked on line, Moho towing a car are not required to have breakaway brakes like when you pull a trailer.
Has anybody installed a warning device if the toad breaks away?
I would like to know if car is breaking loose or has broken away, some kind of alarm visual and sound.
I will be installing tow bar that has surge brake device built in but it doesn't do anything if toad breaks away, it might even add to the problem, if the toad started to break away it would put tension on brake cable causing the brake to be applied hard in the toad, until cable breaks, at that point toad's brakes wouldn't be applied. In trailers the electric brake is activated and continues to stop trailer.
I do have a signal light(small led) shows when toads brakes are being applied, too small to catch your attention, but easy to check when applying brakes to see if toad is too.
Old 01-09-2010, 08:35 AM   #2
richinny's Avatar
2011 34' Classic
a buzzer connected to the signal light would work but first check with the manufacturer. you don't want to overload the signal circuit.
Ricky
Old 01-09-2010, 09:39 AM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Good idea, wire does seem to be minimal for distance, but led doesn't take much power.
I will have to check some of my old buzzers(out takes from seatbelt buzzers) to see how much power they take. Maybe I can use the signal light wire using toads electric as trigger to a selenoid which could power buzzer and light from MoHo power.
Old 01-09-2010, 09:56 AM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Sorry but you are required to have a breakaway switch.
2010 Driving Laws for the US and Canada
This is a list of state requirments
Garry
Old 01-09-2010, 01:43 PM   #5
richinny's Avatar
2011 34' Classic
i think those buzzers draw more than you want. RS has a bunch that should do nicely.
RadioShack.com
Ricky
Old 01-09-2010, 03:26 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Thumbs up
This site says otherwise but yours is a better site and I would believe Woodalls more than this site.
RV Towing Tips
quotes it as not applying to toads, however they do make a switch and it makes sense to have.
The trailer weight limit varies from state to state but by 3000 pounds it is required by all that I read. Very few vehicles towable below 3000.
Old 01-09-2010, 06:45 PM   #7
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Regardless of the law ?? I sure would use a break away brake. they are cheap security
I have a friend that towed a dodge Dakota to Florida each season. they stopped for lunch and when they came out realized the truck was not back there ???
It took 3 days for the Highway patrol to find the truck down over a ditch in North Georgia
John H. is offline   Reply With Quote
Old 01-09-2010, 07:44 PM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Breakaway for sure, but alarm would still announce when it breaks away, wouldn't like that uneasy feeling for three days.
Old 01-10-2010, 10:17 AM   #9
richinny's Avatar
2011 34' Classic
any idea as to what happened to the hitch or the safety chains?
Ricky
Old 01-10-2010, 11:52 AM   #10
Images: 13
Hitch weld broke Plumb OFF He said !!!
It is funny now, that was 15 some years ago
He was from Harden Co. Ohio
No, It was NOT an airstream M.H.
He to this day can NOT figure how he did not feel it break ???
Old 01-10-2010, 06:22 PM   #11
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
If the tow bar system you are going to use is the Night Shift unit, it has break-away protection installed. There is a second cable that goes from the FRAME of the MH to the towd brake peddle. This second cable goes through a one way block, and has an engineered weak link. If the tow system fails, as the towd is leaving the MH, the cable is pulled until the weak link brakes. The brakes of the towd are locked, and stay locked until the one way block is reset.
We are using this system, and are very pleased. You also have proportional braking on the towd with this system.
Rob
Robfike is offline   Reply With Quote
Old 01-10-2010, 10:22 PM   #12
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Thanks Rob,
PO included the system with the mh but didn't show that feature, probably because the cable is there but the one way block probably was mounted on his wrangler and didn't include it. That must be what Night shift is selling for $100. Priced like a boat part, good thing this is a land yacht. ;-)
No antenna signal with digital TV Stream 1529 Audio, Video & TV 18 08-22-2009 05:52 PM
Turn Signal Problem tphillips Lights - Interior & Exterior 4 01-04-2009 04:20 PM
tv signal booster joel Electrical - Systems, Generators, Batteries & Solar 4 08-23-2006 11:05 PM
turn signal problem Cruiser Electrical - Systems, Generators, Batteries & Solar 9 10-25-2004 06:27 PM
