Old 12-01-2011, 07:46 AM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Tire Pressure
Be never been able to find anything concerning 'recommended ' tire pressure for my Airstream. What guidelines do others follow?
Thanks, Derek
Old 12-01-2011, 08:51 AM   #2
1981 31' Excella II
New Market , Alabama
The proper way to do it is to measure temperatures of the tire on the middle and about an inch from each side. Best to do this with an IR thermometer. If you are hot in the middle too much pressure. Hot on edges then too little pressure. I would start at the max pressure on the tire and work down from there. Another way is to use a chalk mark across the tire and drive a few feet. The same principle applies here. If the chalk mark is lighter in the center you have too much pressure.
Perry
Old 12-01-2011, 09:58 AM   #3
crazeevw's Avatar
Thanks Perry. Guess a trip to Harbor Freight is in order. Need to look at max pressure on tires to be sure I'm at least withing 10lbs of max pressure.
Anyone seen what's recommended for Chevy P-30 chassis?
Thanks, Derek
Old 12-01-2011, 04:27 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Changes by tire manufacturer, correct way is to weigh each wheel, average for axle and use pressure on their chart. My tire dealer said he always fills to max, but his usual customers for 19.5 are tow trucks. He didn't know number to use so a told him to set at 80 and I will use the method by Perry above.
Old 12-01-2011, 08:02 PM   #5
crazeevw's Avatar
I'm about to head outside with my puppy. I'll see if I can spot max air pressure on my Michelins.
Thanks, Derek
Old 12-01-2011, 08:11 PM   #6
crazeevw's Avatar
110psi, cold max tire pressure. Noticed when I looked, that there are separate weight ratings for use as a single tire, or on a dual. Interesting, the dual weight rating was lower.
Thanks, Derek
Old 12-01-2011, 08:35 PM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Thanks, Derek
I don't know the specifics on your three axle 34.5 but my 280 runs between 65 and 70 psi. It's interesting that watching my TPMS the tires gain about 10 psi. in just a few miles of travel. The inner duals also run a little hotter if you use the brakes a little. The tires on the sunny side also run a little hotter. Checking pressure on a hot sunny day also will give you some interesting results. What you read on your gauge while you are parked in the morning isn't what your tires see riding down the highway.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 12-01-2011, 08:39 PM   #8
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I have the tires on my 310 at 70 front and 65 rear.
Waipio Rim is offline   Reply With Quote
Old 12-01-2011, 09:28 PM   #9
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
air pressures
Thanks, Derek
Have you tried to get an owners manual from Airstream? Well worth the money. Is there a sticker somewhere on the coach by the drivers seat for tire pressures. Underinflated and they come apart, over inflated and handling can change as well as beating up your suspension. I had a 35 motorhome that called for 90 psi another friend had an earlier one and his called for 70 psi, suspension difference from Ford to Workhorse, same brand and size tires.
arcamedies is offline   Reply With Quote
Old 12-02-2011, 09:50 AM   #10
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Go to the tire OEM site and they will have a chart for inflation pressure/Weight.
Take your unit, with a normal camping load, and have it weighed on a truck scale, wheel be wheel, and axle by axle.
Follow the OEM tire recommendations
Dave
Old 12-02-2011, 10:07 AM   #11
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Wink The Best best way
Dave
There seems to be a lot of best ways posted here. However this (masseyfarm's) post is the one that I believe you will find to be the safest, easiest and most trouble free.
The manufacturer knows the design and capabilities of the tire much better that Joe Blow Salesman at the local gas station or tire dealership.
Ken
Old 12-02-2011, 11:45 AM   #12
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I may be all wet but I try and run about 100 lb. It work for me!!
alfalsetto is offline   Reply With Quote
Old 12-02-2011, 07:26 PM   #13
crazeevw's Avatar
Will scour the driver's area for a label concerning 'recommended' tire pressure. Now that I think about it, I DO have an owner's manual in the Airstream, but don't remember seeing tire pressure recommendations anywhere. Time to pull it out again and peruse.
Thanks, Derek
Old 12-02-2011, 07:51 PM   #14
Central , Mississippi
when I was running a P-30 chassis RV, tires at the max side wall was the rule...
Flats and dry cracking was the end of a tire well before tread wear...103,000 miles when Katrina ate it up.
In hind sight...a better chance of loosing your RV to a hurricane than a tire failure
One less thing to obsess over
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Tire Pressure Questions cooney Tires 9 10-13-2011 09:59 AM
Tire pressure trmiller Tires 46 08-06-2011 04:09 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
