Old 07-19-2013, 10:40 AM   #29
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by graysailor View Post
I run 65 on all four trailer tires. Too new to evaluate long term effects. I am also getting different readings with different gauges.
If you can find the specs on your tire pressure gauges, check them and you will find the accuracy specs can vary significantly. On top of that, drop a gauge just once and its a whole new ballgame. An accuracy of +/-10% is not uncommon with inexpensive gauges. Using that, 65 psi could be anywhere from 58.5 PSI to 71.5 PSI. The only way to be able trust a gauge, is to buy a quality one, test it periodically against a known accurate one and take very good care of it.
you might find this interesting:
Top Tire pressure gauge Ratings | Tire pressure gauge Buying Guide
Ken
Old 07-19-2013, 11:30 AM   #30
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Trailer tires are rated at 65psi in most cases. Speed should not exceed 65mph especially in hot weather and on rough highways. Good luck and happy trails.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Tire Pressure Questions cooney Tires 9 10-13-2011 09:59 AM
Tire pressure trmiller Tires 46 08-06-2011 04:09 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
