Old 12-03-2011, 09:23 AM   #15
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
they say 10 year for the life of a tire.
alfalsetto is offline   Reply With Quote
Old 12-04-2011, 08:27 AM   #16
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I was told by a Goodyear Tire representative, 6 years MAX for use of any tire, passenger car, or RV.
To be honest, my Airstream won't be leaving the county until I have a complete set of 8 new tires. Have too much invested in my dream Airstream to go 'on the cheap' with not buying tires.
NOT going to be like someone I know who says he's driving on his tires until the blow. Let's face it, a blow-out can do substantial damage to our Airstreams. I'm just not going to take that chance.
This is a lifetime dream of mine, will be a short-distance camper until new tires are in the budget.
Thanks, Derek
Old 12-04-2011, 08:34 AM   #17
1981 31' Excella II
New Market , Alabama
If you keep it indoors away from the sun and heat they will last a lot longer.
Perry
Old 12-04-2011, 09:41 AM   #18
crazeevw's Avatar
no space in my garage for a 34.5 foot long motorhome. At some point, I plan on moving into my AS motorhome, and drive, drive, drive. Maybe I'll get some serious use out of the tires then, but until that day arrives, the AS will be parked in my back driveway, just waiting for it's Sunday afternoon drive to blow out the cobwebs!
Thanks, Derek
Old 12-04-2011, 09:41 AM   #19
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Sounds like a long time to me. Life expectancy I have heard starts at about 5 years.
Old 12-04-2011, 09:47 AM   #20
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
When statements like this are made, I find it valuable to consider what vested interest the person making the statement may have.
In this case its fairly obvious.
My entire life, I have replaced tires only when they show signs of needing to be replaced. The secret is to check them frequently and to know what those signs are.
The only blowout or other catastrophic tire failure I have experienced in 52 years of driving was due to my own negligence. I put off repairing a slow leak in in one of my SOBs 4 tires, thinking I could have it done when I got home.
Ken
Old 12-04-2011, 09:56 AM   #21
Lumatic's Avatar
1993 34' Excella
Images: 16
Ken
Other than tread wear, bulges and checking is there anything else you check for?
I have been told that the tire structure deteriorates from the inside out, like dry rot, which is directly related to age and there is no way to check for it. This seems to have been my experience on a couple of older tires which looked good and blew out apparently inexplicably.
Old 12-04-2011, 10:32 AM   #22
Ag&Au's Avatar
That is about what I look for. There other obvious things such as road hazard damage and more than normal scuffing from curbs etc.
I can't dispute what you say, but I have never experienced that. I won't discount the possibility that I have just been lucky. However if that's the case where is my winning power ball ticket.
One other thing to consider is the fact that the evidence of the cause of a blow out is often destroyed by the ensuing damage.
Ken
Old 12-04-2011, 11:01 AM   #23
Lumatic's Avatar
1993 34' Excella
Images: 16
Back too the subject of this thread, tire pressure. If you run a tire at too low a pressure you can cause damage to the structure of the tire that is not apparent. Down the road that tire is more likely to blow out, even if it is reinflated to the proper pressure.
Old 03-22-2013, 01:40 PM   #24
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Then should I run mine at max tire pressure on the tire?
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 03-22-2013, 02:53 PM   #25
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
OPPS I found my answer
http://www.airforums.com/forums/f438...html#post31963
Old 07-15-2013, 09:49 PM   #26
kaylorsan's Avatar
2012 Interstate Coach
Los Gatos , California
I've tried to do the weighing/charts, but have gotten more confused (I'm embarrassed I can't read the charts correctly). I was running the OEM recommendation of 61 PSI (door tag) but was showing signs of under inflation. I'm currently running 65 front and 70 rear with good results to date. Nonetheless, I'd like to dial in pressures based upon my vehicle weight.
Below is the email I wrote to Goodyear. They politely wrote back and said to take it to a tire dealer to discuss.
The charts I'm using can be found here. http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Am I reading the charts incorrectly?
-Kaylor
Hello,
I'm trying to figure out the optimal air pressure for my tires, but I'm a bit confused. I've gone thru your charts, but the answers do not seem right (tire pressures too low).
Tire Size - LT 215/85 - SR16
Weights
Front Left - 1907 lbs Right - 1837 lbs
Rear Left (Dually - single axle, 2 tires each side) - 3043 lbs
Rear Righ(Dually ) 2973 lbs
From the charts, front tire pressure would be based on a weight of 1900 lbs for an inflation pressure of 50 PSI (this is below the recommended OEM pressure of 61). At 61PSI, after ~ 5000 miles, I'm showing wear patterns indicitative of under inflation.
For the rears, pressure would be based on 3043/2 = 1521 which would yield inflations around 45 psi. Which again is under the OEM recommendations (Mercedes Benz Sprinter 3500).
Is there someone that I can speak to about this? I'm guessing that I am doing something incorrectly.
kaylorsan is offline   Reply With Quote
Old 07-19-2013, 07:08 AM   #27
Figment of My Imagination
Protagonist's Avatar
As long as the tires on my Interstate are inflated to 61psi, there is no uneven tread wear after 19 months of use that would indicate under- or over-inflation. When I stop for fuel or at my destination, I put my hand against the sidewalls to check for heat buildup, and the tires are no hotter than the pavement they're sitting on.
The sidewalls may bulge a little bit at the bottom, but that's just a cosmetic issue, not a sign of under-inflation. Most radial tires do that; it's just more noticeable on tires that are heavily loaded as ours are.
If you're getting wear on the edges of the tread but not in the center, indicative of under-inflation, at the recommended 61psi, then I'm not sure why, because that doesn't match my experience.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-19-2013, 08:05 AM   #28
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I run 65 on all four trailer tires. Too new to evaluate long term effects. I am also getting different readings with different gauges.
TinCan
graysailor is offline   Reply With Quote
Tire Pressure Questions cooney Tires 9 10-13-2011 09:59 AM
Tire pressure trmiller Tires 46 08-06-2011 04:09 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
