Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 01-27-2007, 12:36 PM   #1
JVW
JVW's Avatar
Profile:  BRANDON , Mississippi
tire pressure
novia, the original mechelin tires were not rated for 110 psi max. the newer mechelin tire are rated at 110 psi. airstream's 1989 manual recommended that 70psi for the front , 60 psi for rear and 60 psi for the tag. air bags at
55 psi (front). using these pressures you would be well in the limits of the
rims. for the record i use 90 psi all the way around.
have a good one! jvw
JVW is offline   Reply With Quote
dual wheel tire pressure jpurdy Tires 2 10-15-2006 12:03 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 05:40 PM
Tire Problem? Pressure Question montanaandy Tires 1 04-22-2003 09:56 PM
Tire Pressure TBYRNE Tires 11 08-09-2002 10:04 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 02:44 PM
