Old 04-13-2008, 08:10 AM   #1
2005 26' Land Yacht Gas 26
Bedford , Nova Scotia
Tire and Air Bag Pressures
Hi folks: What tire pressures do owners of the Land Yachts use - mine is a 26? I run at the pressures printed on the dash label - 90 on duals 80 on fronts regardless of load. A hard ride but 10+ mpg. The previous owner seemed to like a soft ride and there was only 70 psi in all the tires when I bought the rig. I had to replace all four rears 'cos he had wreaked the sidewalls!
More importantly what pressure do people put in their front air bags. I run mine at 90 psi. It certainly helps to make the rig easier to drive. But what is the highest pressure that can be used? The rig still looks slightly nose down at 90 psi - probably because I don't carry much weight.
Any ideas please?
Thanks, Donald
DonaldW is offline   Reply With Quote
Old 04-13-2008, 09:59 AM   #2
swinginping's Avatar
1989 34.5' Airstream 345
waynesboro , Virginia
On the classics its 55psi for the fronts, but possibly the ly's are different, i dont know much about them... do they carry the p30 chassis or something different??? and i assume they are the inside coil air bags right??
1989 345LE
swinginping is offline   Reply With Quote
Old 04-13-2008, 11:27 AM   #3
Any ideas please?
Thanks, Donald
The front air bags require 55 psi, no more and no less.
interstate tire pressures xrvr Sprinter and B-van Forum 11 09-08-2007 07:58 PM
Motorhome Tire Pressures swebster General Motorhome Topics 11 01-06-2006 08:57 AM
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
Air Bag alfalsetto Mechanics Corner - Engines, Transmission & More... 5 09-27-2003 09:16 AM
