Old 09-21-2009, 08:10 AM   #1
1993 31' Legacy 30
McComb , Mississippi
timer module for defroster in door
We have a 1992 P30 Chassis Airstream Legacy motorhome. Recently we had to replace the driverside window. We unplugged the wires on the timer module housed within the door and now we need to rehook them. Do you know where we can find instructions on a Dana Timer module? It has seven pins labeled 1,2,3,etc. with colored wires. The module is for the defrost on the window/mirror we think.The module instructs that if the wires are plugged in incorrectly that we will damage the module. Can you help?
Thanks.
MS camper is offline   Reply With Quote
Looking for Control Module-Coleman Delta TX DataMover Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2009 02:48 PM
Cruise control module bkahler Mechanics Corner - Engines, Transmission & More... 2 01-10-2009 07:16 PM
ignition module will Classic Motorhomes 6 10-18-2006 08:48 PM
Defroster Problem Orland Dewey Airstream Motorhome Forums 0 12-28-2003 01:44 PM
Hi Perf Module ALANSD Mechanics Corner - Engines, Transmission & More... 0 05-13-2002 07:03 AM
