Old 01-14-2005, 04:11 PM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Tidee Products Plugs in aisle?
As we all know one project leads to another. While working on the ongoing heat problem I discovered that the vents were not aigned properly thus no heat could enter the passenger side when the vent was opened! The heat was directed towards the floor on the wrong side of the fire wall. I needed to tear back some carpet and found mildew which lead to all the carpet being removed. In the process I uncovered two plates in the center aisle labeled: "Tidee Products." These plates have a hole in the center fitted with a wooden plug. Are thses for the central vacuumn system which was never installed in my coach or do they serve another purpose?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 01-19-2005, 12:46 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
these are plugs for the extra dinette table attachments.
I have two in my floor, and when I put in the tables they "hook up" with the main fold out table to become a t shape. These are replaceable. We had a thread sometime ago where there was a link to the table pole legs that fit theses holes. The tables are easily made.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-19-2005, 12:51 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
here is the new table I made, the smaller ones are still the original oak look laminate.
AIR #005
retired!
Old 01-25-2005, 08:30 AM   #4
1994 30' Excella
Thanks for the information. I carpeted over the plugs but did not take out the plates which was my first intention. I will be building a new dinette upon our return from Florida and will not be using the fold out table any longer.
After I get the coach cleaned I will post pictures of our remodel including the new oak console and doghouse.
Chaplain Kent
Old 04-17-2005, 10:20 PM   #5
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
Hay Chaplain Kent, I like to see to photos of the doghouse after you get done. I going to do My in Oak to just as sone as I get My cummins in the My 82
alfalsetto is offline   Reply With Quote
Old 04-19-2005, 07:50 AM   #6
1994 30' Excella
I posted a picture under the thread "classic console" in General motorhome section. There are also several other console pictures from other more accomplished craftspeople.
Chaplain Kent
Window drain plugs AccessMaster Airstream Motorhome Forums 10 06-20-2003 11:37 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
Hitch light plugs ALANSD Brakes & Brake Controllers 4 10-12-2002 09:04 PM
Polishing Blues. TBKP's Overlander Cleaning, Stripping & Polishing 19 10-12-2002 07:57 AM
Electrical testers, and meters thenewkid64 Electrical - Systems, Generators, Batteries & Solar 7 08-10-2002 08:01 PM
