Old 05-26-2015, 12:34 PM   #29
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Alechemist View Post
What type of brakes would you use when towing on a dolly? Would a proportional floor-mounted brake box be effective with only the rear wheels on the ground?
When dolly-towing, you use the dolly's brakes and lights, not toad brakes and lights.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-28-2015, 08:11 PM   #30
1995 36' Classic 36
Ludington , Michigan
thinking of a toad
The pump on modern automatic transmissions is driven by the torque converter which is coupled to directly to the engine. While towing you will not get any fluid flow through the bearings which can lead to failure.
(Important to know on the Allison. Always pull the drive shaft if you have to tow it.)
Consult your owners manual about towing.
I don't know of any automatics that will pump fluid when the engine isn't running except for the power glides of the 50s. They had a rear pump driven by the output shaft. You could actually push start them if you got the speed up enough to enough to produce the pressure to engage the clutches.
Some, especially front wheel drive, run the bearings and gears submerged and can be flat towed.
Kota is offline   Reply With Quote
Old 05-28-2015, 08:18 PM   #31
1995 36' Classic 36
I looked a long time for a decent Samurai. They have a following and have gotten pricy.
Old 07-01-2015, 06:50 AM   #32
SteveH's Avatar
Common Sense , Texas
Anyone here use a Remco drive line disconnect unit on a towed vehicle? If so, what's your opinion of them, please.
Regards,
Steve
Old 07-02-2015, 05:48 AM   #33
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Works, easier pulling out of gear than getting it back in, wife hates sound of grinding gear. I don't like it but the way you line it up is by having the spinning transmission stop at the right place so that it will push in. I don't think I would consider it if it had to put up with slush on the road, here I can spray with wd40 once a year and it is clean.
Old 07-02-2015, 05:56 AM   #34
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We towed a Jeep Wrangler automatic four down behind a 38' SOB MoHo. Transmission in Jeep was in Park when being towed, transfer case was in neutral. Used a Dremco connection and Brake Buddy as Jeep weighed 4,000#. Whole set up worked well.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
paiceman is online now   Reply With Quote
VW Golf III as Toad swebster Airstream Motorhome Forums 4 06-27-2004 08:31 PM
toad hitch zamboni General Motorhome Topics 5 06-09-2004 08:13 AM
Win a Toad! 59toaster Our Community 0 08-09-2003 06:32 PM
toad wiring ALANSD Airstream Motorhome Forums 26 01-05-2003 06:08 PM
Subaru Toad CBBOB Airstream Motorhome Forums 1 11-22-2002 01:01 PM
