Old 06-22-2003, 02:00 PM   #1
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Tag Axle Brakes
What is the proper method for adjusting the tag axle brakes on a 1984 345 motorhome?
I manually actuated the brake controller while coasting and felt no braking. I then jacked up one wheel fully depressed the brake controller and spun the wheel. There was no drag by the brakes. I then measured the voltage at the resistor and found that a little over 6 volts was going to the magnets. I then jumpered the resistor to put a full 12 + volts to the magnet and the brakes worked properly (couldn't turn the wheel). Now how do I adjust the resistor to get the proper voltage to the magnets to make sure that the tag axle brakes do not come on prior to the primary rear brakes? Is there a procedure for doing this?
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 06-23-2003, 01:48 PM   #2
Gunner.
Your motorhome sholud have a "slider" type resistor block.
Take the slider apart.
Clean the bottom and top half of the slider with a wire brush.
Reposition the slider in it's original location, or there abouts.
That will fix your "low voltage." at the brakes.
The problem is the sliders are a "shunt." When the shunt becomes corroded, however slightly, it no longer makes connection. Therefore the entire resistor comes into the circuit, reducing the voltage excessively.
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 08:15 PM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Tag axle brakes for 350 classic Marshall Walters Airstream Motorhome Forums 1 08-29-2003 06:42 AM
Tag Axle Oil Level? swebster Airstream Motorhome Forums 9 08-25-2003 06:01 AM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 09:47 AM
