Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 10-10-2007, 04:22 PM   #1
pjude
Profile:  Tyler , Texas
Suburban furnace
hI! Getting ready for winter here in East Texas ...we did have 2 days below freezing last year so dont laugh. The main furnace in the 345 gets hot enough around the exaust port on the outside to warp the aluminum skin. The major area is above the ports and toward the front of the coach.
I took the cover off and pulled the extensions out and there does not seem to be any reason for this heat. Any help or experience will be appreciated as usual. I also noticed that the furnace will not ignite unless the genset is on. The fan does come on but not the furnace.
Pete
pjude is offline   Reply With Quote
Old 10-10-2007, 04:35 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 82
Unseen obstruction
Originally Posted by pjude
...The main furnace in the 345 gets hot enough around the exaust port on the outside to warp the aluminum skin. ...
Mud daubers are a problem around here.
You may have debris inside the combustion chamber blocking air flow.
Tom
Old 10-10-2007, 04:45 PM   #3
pjude
Furnace
Thanks for the reply Tom...I can see (with flashlight) into the exhaust ports and there is not any kind of obstruction other than a bracket that holds the chrome exhaust cover on. The exhaust seems to be coming out of the pipes as it should but I seem to be getting exhaust that is bypassing the piping.
Pete
Old 10-10-2007, 04:50 PM   #4
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
Sounds like you're not getting enough air flow . Check your air ducts to see if they are blocked off or plugged up . With resticted air flow the furnace will tend to overheat . Also the sail switch will have a hard time getting enough air flow to open the gas valve , probably why you need the genset . It could also be weak batteries .
ticki2 is offline   Reply With Quote
Old 10-16-2007, 09:00 AM   #5
Chuckles
Chuckles's Avatar
Profile:  Iwerne Minster , Dorset. UK
You will need full battery power for ignition (minimum 12.5Volts although it may work down as little as 12.2Volts)
As mentioned above, it would appear that air flow is your overheating problem. It is worth pulling the heater and dismantle all air and chamber ducts. We don't have daubers here in the UK but when our 310 arrived here in the middle of winter after spending its first 25 years in Texas and LA there were dauber nests right inside the fan and surrounding ducts.
Also check that the fan is running at full speed, check for bad connections that will reduce voltage to the motor. Ensure all groundings are good.
Hope this helps.
Low or lack of power plays all sorts of tricks!
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Suburban furnace 34 NT pjude Classic Motorhomes 3 07-29-2007 11:06 AM
Old Suburban Furnace Question Jeffrey Stoecker Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-07-2006 04:11 PM
Suburban Furnace 68LANDYACHT Furnaces, Heaters, Fireplaces & Air Conditioning 9 02-03-2005 10:20 AM
Suburban Furnace tmeagle1 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-20-2004 08:18 AM
Suburban Furnace instructions overlander63 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-03-2003 10:26 PM
