Old 04-22-2013, 06:05 PM   #1
2003 31' Land Yacht 30
amelia island , Florida
sticking brake pedal on 30 Landyacht
Have had it in 2 times and no one can find the issue but brake pedal sticks so each time it is applied, have to pull it back up with foot or the rear brake lights stay on! Have almost been hit 3 times because I did not know it was sticking on.
anyone else have this happen? suggestions on how to fix it?
thanks
snickers is offline   Reply With Quote
Old 04-22-2013, 06:43 PM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Sounds like either the brake light switch is not adjusted right or the brake return spring is weak. It could be a brake linkage or hydro-boost issue as well but less likely. Hard to believe that no one can find the source of the problem.
92landyacht is offline   Reply With Quote
Old 04-23-2013, 07:02 AM   #3
should have explained more. but the pedal itself does not come all the way up. I have to stick my foot under it to pull it all the way up then the light goes out. thanks for helping out.
Old 04-23-2013, 07:46 AM   #4
1992 36' Land Yacht
Grayson , Georgia
As I said, it could be a return spring issue or a hydro-boost problem. How much (travel distance) do you have to pull up on the brake pedal? Do the brakes drag when the pedal is low?
Old 04-23-2013, 05:09 PM   #5
I do not believe the brakes drag at all but never know if the brake lights are on or not?
Old 04-23-2013, 05:51 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
From your location I would look for rust in the pivot point of the pedal or as said in previous post the spring that should pull it back up.
Old 05-16-2013, 02:16 PM   #7
spring has been replaced and now NO brake lights except when needed but now the park brake stays on!1
Old 05-16-2013, 02:25 PM   #8
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Parking brake is completely separate from the service brakes. It is likely the wires on the back of the parking brake switch were "disturbed" when the pedal under-dash work was done.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 05-16-2013, 05:15 PM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Why is it always after a repair something else shows up, especially when service is done in a shop that has closed door due to insurance requirements. Maybe it is just another Murphy's Law.
Brake pedal travel and side pull IPM Mechanics Corner - Engines, Transmission & More... 0 09-27-2009 06:57 AM
Having brake pedal issues and may need rotors SilverToy Brakes & Brake Controllers 10 06-25-2007 04:43 PM
Brake Pedal Stuck To Floor Chaplain Kent Mechanics Corner - Engines, Transmission & More... 14 09-24-2006 12:03 PM
1986 345 AS MH Brake Pedal Travel Jim Tyrney Mechanics Corner - Engines, Transmission & More... 8 04-03-2004 04:47 PM
Brake Pedal Supposed To Be HARD? fangthorpe Airstream Motorhome Forums 8 11-29-2003 01:10 PM
