Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 04-11-2009, 05:13 PM   #1
str8strm's Avatar
Profile:  Tujunga , California
steering wheel re wrap?
On our last trip the leather wrap on the steering wheel started to fall apart. Does anyone know a source that will re wrap it?
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 04-11-2009, 07:51 PM   #2
SaabLover's Avatar
Profile:  1974 31' Sovereign
Almost Always Sunny Sarasota , Florida
Images: 12
Just a guess but if all else fails maybe JC Whitney
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 04-11-2009, 07:53 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If it is just a wrap any auto store should have new wraps. You will need to give them the steering wheel dia. It takes about an hour to stitch one on.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 04-12-2009, 12:59 PM   #4
345bill's Avatar
Profile:  Las Vegas , Nevada
I remember someone else here that described their source/fix for the same problem on their MH. I did a search but I was unable to find it for you. I'm sure it's here somewhere.
345bill is offline   Reply With Quote
Old 04-12-2009, 02:03 PM   #5
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
Any good auto upholstery shop can repair your cover. If the leather is in good shape they can restitch it or if it is too old, make a new one.
They make and repair steering wheel covers all he time. It is a quick easy way to make a $$$$ buck for them.
Would you like to know how upholstery shops make the steering wheel covers?
The way it is done is to first cut a strip of leather that will wrap around the wheel. Run the sewing machine along the edges to perforate the leather. Sew the ends together. Put the cover on the wheel. It should fit tight enough that it almost wraps itself around the rim. Now take a curved needle and sew the cover onto the wheel using the holes you made earlier.
Most guys can do this in under an hour.
Incidentally the reason your old one is coming off is that they used the wrong thread. You have to use nylon thread for auto and boat jobs. The regular cotton thread used for your living room sofa and chair upholstery rots and falls off in the sun. So make sure they use nylon thread.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 04-14-2009, 10:17 AM   #6
str8strm's Avatar
Thanks to all
for the information
AIR 7992
Steering Wheel replacement rvlover Classic Motorhomes 19 09-21-2008 08:17 AM
Sloppy Steering... Auretrvr Classic Motorhomes 46 11-12-2006 02:23 PM
Re: steering Orland Dewey Airstream Motorhome Forums 0 11-24-2003 05:02 PM
steering stabilizer cooperhawk Mechanics Corner - Engines, Transmission & More... 3 07-17-2003 05:37 PM
GM option--4 wheel steering Kistler Our Community 4 01-08-2003 03:30 AM
