Old 02-20-2008, 06:27 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Steering Column on 2003 AS LY 30'
Two things happening that I think are related to pinched wires in my steering column. It's a 2002 Workhorse Chassis (Gas) that gives me fits. First-when I move the steering column I loose brake lights (left & right) but not the center light. The other is the horn blows constantly, I pull the fuse to make it stop. Has anyone experienced this situation? Has anyone removed the steering column cover to expose the wiring? and what did you do if they are pinched and grounding out? Thanks for your support.
Steve
spat61 is offline   Reply With Quote
Old 02-23-2008, 09:23 AM   #2
Steve,
Most of the motorhome owners on Airforums have the older Chevy P30/32 chassis and they likely don't have the same steering column arrangement as your 2003 model. There are a LOT of knowledgeable mechanics here however that most likely will be able to help you out.
Can you post some pictures of what you're referring to? As the old saying goes, pictures are worth a 1000 words .
Old 02-24-2008, 09:04 AM   #3
spat61's Avatar
Steering Column
Brad,
You are correct about pictures. I will post a few to better express my problem. I might have mentioned that it is a 2002 chassis but the coach is 2003. It looks the same as the 2000 chassis dash and steering column that I looked at before I purchased my present 2003. Thanks for your response.
Steve
Wiring Inside Steering Column spat61 General Motorhome Topics 1 01-26-2008 07:06 PM
2003 30' Land Yacht Parts spat61 Land Yacht/Legacy Motorhomes 2 01-04-2008 08:13 AM
Wiring Diagram for Steering Column spat61 Land Yacht/Legacy Motorhomes 0 12-13-2007 10:24 AM
2003 30' Land Yacht spat61 Land Yacht/Legacy Motorhomes 3 11-19-2007 05:32 PM
2003 30' Classic..TMV opinion???? AZstreamin Trailer Values 13 04-26-2006 09:05 AM
