Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 03-09-2005, 01:53 PM   #1
85/345
Profile:  Marietta , Georgia
Sound Deadener
I am putting new carpet around the pilot, co-pilot and doghouse and was wondering if I should use sound deadener or just plain old carpet padding. Don't really know if the sound deadening insulation will make that much difference. I am looking at Dynamat and from what I've heard it works pretty well. Has anyone had experience with this stuff? Is it worth the extra money? If you have any other ideas let me know.
Brian
85/345 is offline   Reply With Quote
Old 03-09-2005, 02:58 PM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 215
Brian:
You may want to visit this thread:
http://www.airforums.com/forum...ad.php?t=15091
When I pulled up my old carpet there was no padding under it in the pilot/copilot area - I installed the new carpet with a good quality commercial (heavy density) foam pad (except for the doghouse - left the original carpet on and covered it over).
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 03-09-2005, 08:05 PM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I also redid my carpet in my MH. I padded the floor in the cockpit with a high quality pad as well as the carpet. I added the heat and sound insulation under the lid of the doghouse, 2 layers thick. I also added additional padding between the steel of the doghouse cover and the wood underlayment of the cover with carpet on top.
It sounds like a lot of work, but I can tell you that you can have a normal voice conversation with your passenger like you would in your daily driver. That makes long drives easy and less stressful.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-09-2005, 10:16 PM   #4
IceKing02
IceKing02's Avatar
Profile:
Dynamat and others
85/345,
I am, this very night, putting together my truck after taking apart the doors, floors and everything not nailed down. I put in two layers of B-Quiet Extreme and one layer of V-comp. I'll tell you in the next couple of days if it is the "bank vault" that it already appears to be. Conversation in a low voice has not been an option prior to this modification. The website for this product is www.b-quiet.com and it was quite easy to order, ship and install. I can only tell you right now that my doors close with an authoritative THUNK, as if they are solid steel. Kinda cool...
"Few things are impossible to diligence and skill" -Samuel Johnson
IceKing02 is offline   Reply With Quote
Old 03-09-2005, 11:19 PM   #5
mcneon
mcneon's Avatar
Profile:
I'd highly recommend checking out some of the high-tech insulating materials. These tend to be expensive, but they're very effective and thus worth the cost, IMHO.
The B-Quiet site has some good products. I chose one from J. C. Whitney, their P/N ZX158488B, and I've been very pleased with the results. It insulates against heat as well as noise. I used this same material to line my generator compartment, and it's very quiet.
It seems that now I actually get more engine noise through the floorboards and firewall than from the doghouse. I'm in the process of recarpeting the front compartment, and I intend to use the same material as a carpet pad, at least on the sheet metal parts of the floor.
mcneon is offline   Reply With Quote
Old 03-11-2005, 06:51 AM   #6
74Argosy24MH
Profile:  LOST , Hawaii
I used the same material and with the same results, more noise now from the floor and firewall than engine. The only time I really hear the engine is when the fan clutch kicks in.
For the floor and firewall I think the way to go is spray insulation because of the irregular shape. I used some spray ceramic heat insulation on my inner roof and the temperature reduction was amazing.
John
74Argosy24MH is offline   Reply With Quote
Old 03-11-2005, 07:15 AM   #7
driftwood
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
Quiet !
Who can be more particular than expensive yacht owners?
In the U.S. Mega-Yacht industry the leader in sound reduction technology can be found here: http://www.soundown.com/
No doubt your 'Land-Yacht' is worth it!
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 03-11-2005, 07:38 AM   #8
87MH
87MH's Avatar
Images: 215
Originally Posted by 74Argosy24MH
....... used some spray ceramic heat insulation on my inner roof and the temperature reduction was amazing.
John:
Do you have a make or website for the ceramic spray?
That's a new one on me.
THanks,
Dennis
WBCCI # 1113
AirForums #1737
Old 03-11-2005, 08:16 AM   #9
74Argosy24MH
You betcha. It ain't cheap, and has gone up since I got it even. It has to be something repackaged because I couldn't find it anywhere else under that name.
http://www.partsexpress.com/pe/showd...number=268-232
It really works. I made the inner roof above the cab and had it laying outside in the sun. It was so hot I could hardly touch it to bring it inside. Sprayed it, put it back outside and the bottom was barely warm.
John
Old 03-15-2005, 04:42 PM   #10
85/345
I have been looking and I am leaning towards the b-quiet. Mainly because of price, 50 sq. ft. cost $130 where as 36 sq. ft. of Dynamat cost $250. And if I buy it on ebay I can get it even cheaper, around $100. I am just curious, for those of you that bought the b-quiet, which type did you get? I am looking at the bquiet ultimate. Another question what should the temperature rating be? For the bquiet ultimate the temp rating is 311 degrees.
I called the Soundowner, noise deadener used in yachts, and they are sending me some samples. They wouldn't quote me a price over the phone for some reason, but they are sending me a price sheet.
Brian
Old 03-15-2005, 07:04 PM   #11
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
what about the neoprene sound deadener I saw on Ebay? Looked like a good product at a fair price. Supposedly used in Boeing aircraft.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 03-16-2005, 10:31 AM   #12
85/345
Looked at the neoprene and was concerned about the ease of installing it. From what I read you have to use spray adhesive or something similar to install it. I have never really had any luck with the spray adhesives, could be I was just using the wrong kind. With the others they already have adhesive on them.
Was thinking and realized all I need on the floors is a pad that will help reduce the noise, I don't need any heat shield. The only thing I need a heat shield on is the doghouse cover. Am I right in thinking this way?
Brian
Old 03-16-2005, 10:58 AM   #13
IceKing02
IceKing02's Avatar
Profile:
b-quiet!
85/345,
I put in about two layers of the Ultimate (self-adherent) and then put down one layer of the V-comp. I used 3-M spray adhesive on the doors with excellent adhesion results at 24hours. I now drive around with more of a "bank-vault" feel and the stereo sounds "tighter" if that is the right way to say it.
There is no adhesive required for floors but is may help to keep it from bunching up under the floormats.
IceKing02
Old 03-16-2005, 11:29 AM   #14
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Ceramic spheres source. They have a range of products.
http://www.hytechsales.com/prod1000.html
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
F-18 Breaking sound barrier FrankR Off Topic Forum 7 12-16-2004 11:11 PM
better banquette sleeping? nellie the elephant General Interior Topics 6 04-20-2004 10:36 PM
1977 Ambassador - Does this sound like a good start? kittypants General Repair Forum 1 07-20-2003 09:23 AM
WBCCI membership Kistler Our Community 4 11-11-2002 06:56 PM
