Old 05-26-2005, 08:00 AM   #29
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
when I re-carpeted my MH I added standard carpet pad under the carpets in the driver and passenger area. There was none originally. This made a big difference. I have also used the heat reflective sound deadening materials that CW sells in a kit. It works very well. The biggest issue I see is keeping the "insulation" or sound deader dry. I know that there is a honeycomb lead sheet material out there that is used to quiet generator compartments.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-12-2005, 01:36 PM   #30
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Lining generator compartment
Hi all,
My generator compartment was lined with some shiny (mylar?) stuff over a thin layer of foam. The shiny stuff separated from the foam and was flapping around loose inside the compartment. When the cooling fan for the generator came on (generator is a water cooled Honda) it sucked the shiny stuff up against the radiator cutting the air flow through the radiator causing the generator to heat up and shut itself off.
I'm, thinking of lining the compartment with this stuff: http://www.b-quiet.com/hliner.html. Does this seem like a good idea?
Any other suggestions?
guy99 is offline   Reply With Quote
« RV info | Top | RV Makeover »
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
F-18 Breaking sound barrier FrankR Off Topic Forum 7 12-16-2004 10:11 PM
better banquette sleeping? nellie the elephant General Interior Topics 6 04-20-2004 09:36 PM
1977 Ambassador - Does this sound like a good start? kittypants General Repair Forum 1 07-20-2003 08:23 AM
WBCCI membership Kistler Our Community 4 11-11-2002 05:56 PM
