Old 03-16-2005, 03:17 PM   #15
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
That stuff sounds amazing, R-24 with 15 mil thickness! Maybe I should take off the inner skin and coat the inside of the outer skin? Seems like it would make it nice and cozy.
Kind of expensive, I guess.
guy99 is offline   Reply With Quote
Old 03-16-2005, 04:21 PM   #16
Over59's Avatar
Putnam , Connecticut
Images: 37
I wouldn't get to excited about that R-24 number. Has to be "modified" test. Still I'll use it between the sheets in combination with the reflective foil with a foam cord.
Over59 is offline   Reply With Quote
Old 03-16-2005, 05:39 PM   #17
mcneon's Avatar
Originally Posted by 85/345
...I have never really had any luck with the spray adhesives, could be I was just using the wrong kind...
I've used 3M Super 77 spray adhesive in the past, but it's no good if you need resistance to high temperatures. It will soften and melt, leaving a gooey mess on everything it touches. This is especially true if you're gluing headliner material or convertible tops - ask me how I know!
The trick is to use a true contact cement, whether aerosol or liquid. J. C. Whitney offered a special spray adhesive for use with its soundproofing material, and it has proven very satisfactory. It stuck firmly and quickly to the underside of my doghouse and hasn't shown any signs of loosening over about 1-1/2 years.
mcneon is offline   Reply With Quote
Old 03-16-2005, 07:37 PM   #18
LOST , Hawaii
Was thinking and realized all I need on the floors is a pad that will help reduce the noise, I don't need any heat shield. The only thing I need a heat shield on is the doghouse cover. Am I right in thinking this way?
Brian
I would reconsider not thermally insulating the floor. The fan or airflow thru the radiator blows heat everywhere and you are sitting right over it.
John
74Argosy24MH is offline   Reply With Quote
Old 04-01-2005, 10:55 AM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used some rubber underlayment left over from a flooring project to insulate around my dog house. Seems to make a nice difference in the sound level. I intend to double it and lay it under the front carpet. I also found a source for a stick on padding that could go up inside the firewall area...very reasonable. I bought a sample..it looks like it would do a great job. Check it out here---
http://www.sciplus.com/singleItem.cf...LogFrom=Search
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-01-2005, 01:08 PM   #20
Images: 59
Originally Posted by ALANSD
what about the neoprene sound deadener I saw on Ebay? Looked like a good product at a fair price. Supposedly used in Boeing aircraft.
Uh-oh. I wouldn't try anything used by Boeing.
They need to re-insulate 1600 aircraft because of an insulation 'fire hazard'.
Old 04-01-2005, 06:04 PM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
guess my Moho would have a hard time getting off the ground then too....well I can always call Lockheed..they're right down the road from us.
AIR #005
retired!
Old 05-23-2005, 03:09 PM   #22
LeeMo's Avatar
Acworth , Georgia
Arrow Hush Mat
I recently read an Article featuring an audio system upgrade in an Ford E-350 van that also used a sound-damping product called Hush Mat. Hush Mat is a pliable material that will adhere to the multiple contoured surfaces with our surface preparation or heat, and it can be easily cut to shape. It is designed to create a barrier that eliminates vehicle squeaks, rattles, engine growl, and road noise. Check out their website: www.hushmat.com
LeeMo
1979 24' Excella Motorhome
LeeMo is offline   Reply With Quote
Old 05-23-2005, 03:44 PM   #23
Send a message via Yahoo to Boats13
serious db reduction
I just called the local (Marietta) distributor, for a bulk pack: 399. +tax
Thirty (30) 12.1" x 23" Sheets available in either black or silver. 58.7 square feet (17.9 square meters). A Bulk Kit is enough to treat an entire mid-size or smaller vehicle. Utilize a Bulk Kit to supplement the other kits above. Or simply purchase a Bulk Kit and apply as needed.
Boats13 is offline   Reply With Quote
Old 05-25-2005, 07:09 AM   #24
1985 34.5' Airstream 345
Marietta , Georgia
Send a message via MSN to 85/345
In my opinion I would go with the b-quiet product because of price. All the products, b-quiet dynamat hushmat, are pretty much the same thing. They are all a black tar type product with a metallic backing. The only difference is price, b-quiet cost about half what the others cost. I bought it and it is very easy to cut and apply, make sure you get the roller or a roller, helps a whole lot when installing.
85/345 is offline   Reply With Quote
Old 05-25-2005, 07:56 AM   #25
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Hey lay off Boeing....their locals round here lately.
Old 05-25-2005, 02:10 PM   #26
LOST , Hawaii
I wonder how much that would weigh, could be pretty heavy even in a motor home.
John
Old 05-25-2005, 05:49 PM   #27
heavy stuff, man!
I emailed them the q on weight. I will post reply.
CT
Old 05-26-2005, 07:54 AM   #28
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Now that I am driving with a 2005 engine which is whisper quiet at almost any speed I find that all my noise comes from the road. I need to find a way to sound proof the firewall in front of the driver's and passenger's feet. The silver stuff used by Airstream is useless, then there is all the glass and I wonder what is in the headliner besides plain old insulation.
I reall should not be complaining since my wife and I can carry on a conversation at normal voice while doing 60 on the interstate. However, there is still room for improvement.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
« RV info | Top | RV Makeover »
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
F-18 Breaking sound barrier FrankR Off Topic Forum 7 12-16-2004 10:11 PM
better banquette sleeping? nellie the elephant General Interior Topics 6 04-20-2004 09:36 PM
1977 Ambassador - Does this sound like a good start? kittypants General Repair Forum 1 07-20-2003 08:23 AM
WBCCI membership Kistler Our Community 4 11-11-2002 05:56 PM
