Old 01-25-2017, 02:27 PM   #1
Venice , California
Smallest Motorhome Airstream Made?
I am on the search for the smallest motorhome/van Airstream has made. I found and have fallen for a 1975 Argosy 20', but it is about 10' longer than I want. Any advice or information on something smaller with a similar body shape? Thank you!
TLuchford is offline   Reply With Quote
Old 01-25-2017, 02:41 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you go for a Van you are going to have to compromise your wants.
2004 Excursion 4x4
Old 01-25-2017, 02:42 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Well the B190 was the shortest MH at 19', but the Argosy 20' is the shortest classic shape by 4'. Bare in mind a Argosy 20' has a 6' cockpit and 14' body so any smaller and it wouldn't function as a camper.
martin300662 is online now   Reply With Quote
Old 01-25-2017, 02:49 PM   #4
Gainesville , Florida
Shortest, B190. Or maybe airstream Avenue.
Old 01-25-2017, 04:33 PM   #5
Alluminati's Avatar
St. Louis , Missouri
A 20' motorhome is 10' too long?
A Honda Civic is 15' long, so you're asking for a motorhome that's 5' shorter than a Civic.
The Morgans
1989 Avion 34VB
Alluminati is offline   Reply With Quote
Old 01-25-2017, 05:11 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
In 1967 I saw a cube van. It was made by cutting a VW van in half and shorteni g it so much that the rear wheels were inches from the front. Cute as could be. And impractical! OMDGIH! Even too cool for a Shriner to own... cornering at over 15 mph probably wrecked most of them.
Look for a thread with PEANUT in the title to see how cute a 20 is.
Old 01-25-2017, 05:14 PM   #7
2005 30' Classic
Burlington , Ontario
My Classic 1979 Austin Mini is 10' long - not sure it would make a great motorhome
though ....... maybe if it was 30' high with several floors.
Brian.
Old 01-26-2017, 12:03 AM   #8
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
This has got to be a joke lurker
Boom Sounds is offline   Reply With Quote
Old 01-26-2017, 12:35 AM   #9
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I did consider this myself at one point Nick, not as a camper but as a van (and a use for my donor camper).
Much like the VW microvan conversions (where they cut the sliding door section out of the middle of the bus, and which sell for good money at auction), you could do something similar on a classic shape MH
If you look at the bare chassis and body you could loose 3ft out from between the wheels (see the section between the windows on Bella)
But the difference between a VW van and a classic is the VW has cab doors so you can effectively remove the center door. On a classic that is the only entrance so you would have to do something drastic. I was toying with the idea of hatching the rear and making a hauler for my bike so I could loose the door.
Even with loosing another 3ft from removing the door you would have 8ft of body and 6ft of cockpit and a length of around 14ft.
Hardly practical but pretty cool!
I definitely would not start with a rare model like a 20ft, the same mods can be applied to a more common 28ft.
I even had it booked in with the guys at Barillaro Speed Emporium before changing my mind!
Old 01-26-2017, 05:37 PM   #10
Venice , California
This is super helpful! Thank you!
Old 01-26-2017, 07:51 PM   #11
1987 25' Sovereign
Oregon , Ohio
How about a camper in the bed of a Ford Ranger Or a Chevy Colorado ?
msmcv51 is offline   Reply With Quote
Old 01-27-2017, 02:28 AM   #12
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Just remember the primary reason that the VW bus can be cut and shunted is the fact that it is a rear engine/transaxle.
In getting a P-30 chassis shortened you are limited by the length of the engine/transmission and the minimum distance from the end of the transmission to the rear axle to allow for the travel of the rear suspension (in terms of the drive shaft). Maybe easier to drop a classic body onto a front wheel drive chassis!
Single vs. Tandem and Smallest tandem axle JimGolden Airstream Trailer Forums 27 11-29-2009 09:04 PM
Probably stupid question: Smallest vehicle to pull Airstream? mrs.romance WBCCI Forum 9 09-07-2009 12:28 PM
Airstream's smallest / lightest trailer SzochIsOn1st Off Topic Forum 31 09-20-2008 07:02 AM
Smallest Twin Axle Airstream? craftsman Our Community 13 07-15-2007 12:40 PM
smallest airstream with seperate bedroom? tom wolseley 1974 - 1979 Safari 11 05-14-2006 11:08 AM
