Old 09-21-2004, 06:06 AM   #1
1976 28' Argosy 28
Lansing , Michigan
simply questions
Could anyone shed some light on a few simply questions? Can I run the gen while I am driving? Any potential problems with it? Also, I see in the owners manual that the 28 ft Argosy has a Vacuum outlet? Where is this located and does all 28 ft MH have this feature. The MH is new to me and not where I can look at it. Any held would be appreciated. Thanks!!!!
tandemfish is offline   Reply With Quote
Old 09-21-2004, 06:21 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Yes, the gen is designed to be running while you drive.
I have a canister type vaccuum cleaner in my 28. It is located in the small closet in the rear bath. It requires a cartridge filter (NLA) and a hose.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-21-2004, 08:33 AM   #3
1976 28' Argosy 28
Lansing , Michigan
Is the canister where you can see it or is it hidden. In the manual, it looks like it should be in the pantry to the right of the refrig. Is this correct? Also, was this an option or a standard appliance? Thanks a ton!!!!!
Old 09-21-2004, 08:43 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
My 82 does not have the vacuum. Th canister on yours looks like a can, standing up in the closet area, towards the bottom. Its a nice feature, optional.
I run the generator when driving for a/c roof use, and the kids tv. I bought a small inverter to use Tv and video games when driving and the generator is off.
The only problem running the gen is it uses more gas..but only a gallon or so every hour or two it runs, depending on the load it has on it.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Argosy newbie with questions Montag All Argosy Trailers 5 08-03-2004 11:37 AM
Novel questions scribbler Our Community 16 05-05-2004 07:57 AM
Questions from the UK from a 1st timer! 1984air310 Airstream Motorhome Forums 41 03-04-2004 10:56 AM
Questions from a new A/S owner. Help. bluvalley Hitches, Couplers & Balls 6 10-30-2003 10:58 PM
