09-10-2015, 08:10 PM
#81
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
And for the ambitious among us, there are 2 more ways to do it:
If you open up the window channel on the top, you can actually push that piece of trim back far enough to slide the old out and the new in, but it involves disturbing the fixed window gasket and I don't recommend doing it.
See the picture below, sorry for the bad quality
The other way would be to cut a Y with a dremel tool, like 2 railroad tracks meeting and sliding the new seal in that way.
AIR #13
12-01-2018, 08:00 PM
#82
1988 32.5' Airstream 325
WhereIam
, Left Coast Proud
HELP! Window Slide Tracks
Can any of you tell me where to buy the Window Slide Tracks? We have a 1988 325 Classic Moho.
12-01-2018, 08:13 PM
#83
2023 30' Globetrotter
Pleasanton
I think that the aluminum track you're holding and not the gray rubber seal part, right?
For aluminum extrusions, I would call Airstream directly or an Airstream dealer/restorer. I think they are still available, but I have not purchased thsi specific one. A similar item that I needed was aluminum extrusion track for the curtains in (what was) my moho. I couldn't find it on the website of my usual parts website (out of doors mart), but the same place is an Airstream dealer so I called them. They had the extrusion available in bulk but not listed on their website. They cut the length that I needed and shipped it to me.
That being said, I needed a seal to go around the black tank drain for my current Airstream trailer and that same dealer ordered the part through Airstream directly and had it drop-shopped to my house. So it can go either way.
12-02-2018, 05:20 AM
#84
Richmond
, Kentucky
That plastic track is not longer available. Airstream doesn't supply it and no one has been able to find an alternate source. A few people of have tried and failed to reproduce them.
Should you find a source please let us know where you found it!
Sorry to be the bearer of bad news.
1975 24' Argosy Motor Home
12-08-2021, 06:24 AM
#85
1989 29' Airstream 290
Hannover
, Germany
Hi Brad,
As the post is some years old, was somebody able to find the plastic window tracks or a suitable replacement?
I have to do my ones soon - just looking for options.
Thank you,
Mario
12-08-2021, 06:36 AM
#86
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Do you have access to a 3D printer Mario?
Brad has the CAD files to allow them to be printed.
12-08-2021, 07:59 AM
#87
Richmond
, Kentucky
Originally Posted by AirStreamMar
Hi Brad,
Thank you,
Mario
Mario, as Martin mentioned if you have access to a 3D printer I can supply the necessary files.
Before replacing any tracks you should check to see just how many are bad and need replacement. Frequently the tracks at the top of the window are still good so you would only need tracks for the bottom.
The tracks that I've reproduced require two pieces to replace one original Airstream track. So for one window if you are replacing top and bottom tracks you would need four pieces printed.
My printer can only print something that is about 11-1/2" long so when I designed the new track I made it as long as I could.
If you can't print them yourself or find someone to print them I could probably print them for $15 plus shipping for two pieces to make one track, i.e. bottom track.
12-08-2021, 09:53 AM
#88
Hannover
, Germany
Hi Brad and Martin,
Thank you for the feedback. As shipping to Germany would be quite expensive it might be better if I print them out. We recently visited a workshop where you could use on-site all tpyes of equipment, including a 3D printer. Might be also a good experience for me to do this the first time (a man has to get a child, plant a tree and build a house in his life... and use a 3D printer). Sure, there is somebody to guide me. So if you could send the files that would be great. I could then also ask the German Airstream fellows who needs some tracks and help them out as well.
Regards,
Mario
12-09-2021, 08:23 AM
#89
Richmond
, Kentucky
Hi Brad and Martin,
Regards,
Mario
PM me your email address and I'll see if I can send them via email.
12-13-2021, 02:29 PM
#90
1991 25' Airstream 250
Oxford
, Oxfordshire
Hi Brad and Martin,
Regards,
Mario
Hi Mario,
Would you mind printing me two and then ship to the UK. All costs covered of course. Please PM me if possible many thanks Nick
12-14-2021, 12:14 AM
#91
Hannover
, Germany
Originally Posted by Boom Sounds
Hi Mario,
Hi Nick,
Sure will do. But will be early next year only. Will send you a PM.
Regards,
Mario
12-15-2021, 12:08 AM
#92
Oxford
, Oxfordshire
Hi Nick,
Regards,
Mario
Danke schön
12-15-2021, 12:41 AM
#93
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Danke schön
Just remember we have to pay duty on imports from Germany since Brexit and as the rails are made from unobtainium, the value will be high!
Seriously though I bought a 3D printer (I think the same as Brad's) but haven't got any further than putting all the boxes in the garage - I hope to try and make some headway in getting it setup over Christmas.
If I can figure out how to get it to work, then I maybe able to help. Although I may end up getting frustrated and simply putting it back in the box!
12-15-2021, 12:54 PM
#94
Richmond
, Kentucky
Originally Posted by martin300662
....If I can figure out how to get it to work, then I maybe able to help. Although I may end up getting frustrated and simply putting it back in the box!
The older you get the easier the decision is to just put it back in the box....
01-14-2022, 04:28 PM
#95
Airstream Driver
1994 30' Excella
Austin
found a good replacement for the fuzzy of the cockpit windows. Unfortunately it only comes in 100' rolls but is fairly reasonable ($30-40 with shipping). The same place also offers the AS1268 channel seal
The Torrami fuzzy that has been suggested before (see picture) comes with a very sticky backing that is hard or impossible to slide into the channel.
I decided to use both to put an end to the air gap. I used DK hardware stuff in the channel and the sticky right next to it on the appr 1/4" flat surface next to the channel. To remove and reinstall the channel fuzzy a notch (see picture with red line to show the cut ) needs to be cut to slide it out and back in.
AIR #13
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Opinons wanted on truck shell or cover?
Safari Tim |
Our Community |
20 |
07-15-2003 04:46 AM |
M/H Windows
uncleneal |
Mechanics Corner - Engines, Transmission & More... |
6 |
08-04-2002 01:34 PM |
Argosy Interrior
manley |
Upholstery, Blinds, Walls & Interior Finishes |
5 |
04-17-2002 10:28 AM |
