Old 08-28-2011, 02:14 PM   #15
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
What about POR-15? I've used it for many years on automotive engines and underbodies. I used the POR-15 process last year on our airstream's A-frame when I installed our 3P. I will use this process on the rest of the frame in October when I replace the axles. I'm also going to use it on our ProPride 3P this fall or whenever Shawn is able to send new hardware for our 3P.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 09-05-2011, 07:08 PM   #16
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
I used a 3 M product similar to this 3M I can not recall the number there are 3 or more different ones.
AirRowan is offline   Reply With Quote
Old 08-05-2012, 01:27 AM   #17
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Rust protection
1 Prep and clean all surfaces, using wire brush, scraper and ideally steam cleaner. Try and find a company who steam clean buses etc and get it on a ramp
2 Use a rust convertor which eliminates any surface rust. Coat chassis rails and other easily accessible areas with a 2 part paint solution, ideally, Rustbuster EpoxyMastic 121. POR 15 also make some good quality products.
3 Use Dinitrol (can be sprayed) into harder to access areas e.g. cavities etc. This is widely used by the MOD in the UK on their Landrover fleet. This meets their spec which states that their vehicles must be able to be driven in 1m of salt water.
Don't waste time with inferior products, some of which are market leaders, unless you want to re-do the work every year!
Boom Sounds is offline   Reply With Quote
