Old 11-20-2010, 08:57 PM   #1
1992 30' Airstream 30
topanga , California
Run Coffee Maker on Inverter??
Is it possible to run a 110v coffee maker off the batteries? I thought I did it once when I got the rig 10 years ago, but the coffee maker I have now doesn't work and sounds like it's blowing a circuit breaker after 15 seconds or so.
Everything works fine with the generator on but I hate firing the Onan to make coffee at 6AM.
andyleonard is offline   Reply With Quote
Old 11-20-2010, 09:04 PM   #2
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
So what's wrong with buying a $20 metal Coffee pot and using the propane stove?
RichHog is offline   Reply With Quote
Old 11-20-2010, 09:05 PM   #3
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Andy, you should be able to make coffee utilizing the inverter with no problem as long as you aren't overtaxing the circuit you're on. Have you had success in using other appliances on the inverter? One thing you may want to replace the breakers on your Onan as they may be weakened and not truly giving you 20amp or 30amps. I replaced the breakers on my Onan today as the inverter was tripping the 20amp breaker when it kicked on to charge the batteries... changed them out and it works perfectly.
GREENovaters is offline   Reply With Quote
Old 11-20-2010, 09:15 PM   #4
They don't have a store at the racetrack where I'm parked.
Old 11-20-2010, 09:18 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
That's what we did.
Hi, I bought a stove top percolator just in case we ever didn't have 120 volt electricity. On our last trip, we were headed for the Grand Canyon North Rim, where my brother told us about a full hook-up campground there. Well when we got there, the one and only full hook-up campground was closed for the season. So we brought out our stainless steel, stove top, coffee maker and used it for the two days stay. We liked the coffee so much better than from the plastic coffee maker that we usually use. [120 volt] So for the rest of our trip, and probaly from now on, this is what we will use.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-20-2010, 09:21 PM   #6
So theoretically I CAN make coffee using only the batteries? I haven't tried any other high-draw appliances in the plug over the sink, but the phone chargers, etc. work fine.
I don't understand what the breakers on the Onan have to do with the inverter. The generator will run the AC units without blowing anything, so I assume they're good. They feel a little floppy when you move them, but they don't blow. Are you saying that too much draw on the inverter - with the Onan off - will blow the breakers on the Onan?
Old 11-20-2010, 09:26 PM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
OK, so put water in pan. Turn stove on, light burner, when water comes to a boil remove pan. Pour water over coffee filter in 110V Coffee Maker. Drink Coffee
Haven't tried this yet but seems like it would work.
Old 11-20-2010, 09:33 PM   #8
Without question I will pack one along next trip. My immediate problem, however, is how to get coffee at 6 tomorrow morning without waking everyone camping in the pits at the track up by firing the Onan.
Old 11-20-2010, 09:35 PM   #9
Rich, I have an idea......you come over tomorrow morning and make coffee for 8 guys on the stove while I put the gearbox on the racecar back together.
Or....you could help me out by answering my original question regarding the inverter.
Thanks.
Old 11-20-2010, 09:42 PM   #10
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I think I'd rather take my chances and run the Onan at 6 than deal with 8 grown male adults without coffee in the morning. If anybody comes knocking on your door mad about it, I think the 8 guys can convince them to go back to bed.
Old 11-20-2010, 09:43 PM   #11
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
How many watts is your inverter rated at and how many watts does your coffe maker require
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 11-20-2010, 09:58 PM   #12
Not enough and too many, would be my guess. The inverter seems happy to charge the phones and run small stuff, but the coffee maker switch doesn't light up like it should and after about 15 seconds the inverter stops buzzing. I guess maybe I need a smaller coffee machine....or a pot. The inverter seems to be buried under the bottom shelf under the sink...no easy access... or maybe even in a sort of vented box slung under the coach. Someday, far from now, I'll check it out.
I'm told there are only 12 1992 300LEs made and this one was delivered with an owner's manual for something else that's often close and sometimes way off, so without going in there...I don't know what I've got.
Old 11-20-2010, 10:04 PM   #13
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Are there any other 12V devices you can turn off so that full power goes to the coffee pot?
Old 11-20-2010, 10:05 PM   #14
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
How many watts is your inverter rated at and how many watts does your coffee maker require
Bingo...your coffee maker can't be rated for more watts than your inverter. The factory inverter in our 06 19' Bambi is only a 600w inverter...so anything we want to run using it has to require less than 600 watts. If there's a heating element involved, chances are you will need more than 600 watts. (You can usually find the wattage requirements of appliances somewhere on the info/spec plate.)
We, too, have a stove top Farberware coffee percolator and it makes GREAT coffee! We carry a small drip coffee maker, but we really prefer the perked coffee's flavor.
By the way, I don't think it makes any more noise getting a percolator ready to make coffee than a drip coffeemaker. You can also get it ready to perk the night before and simply turn on the gas the next morning.
If you don't have a percolator, get your drip coffee maker ready to roll, but instead of putting in cold water and plugging it in, boil water on the stove and pour it into the filter/coffee basket of your drip coffee maker. Voilá...hot coffee.
Then you can wake up and smell the coffee.
TB & Greg and Abbey Schnauzer
#3954
Good coffee maker for a trailer? WineStream Stella's Kitchen 421 10-31-2015 10:08 PM
Inverter to run refer while driving... lilynhoward Batteries, Univolts, Converters & Inverters 26 11-21-2010 02:06 PM
Installing Inverter to run all AC outlets in Airstream Interstate Aahj Batteries, Univolts, Converters & Inverters 6 05-17-2010 07:22 PM
Inverter/Generator Run on LP judybug Generators & Solar Power 1 05-13-2010 08:47 PM
