Old 11-21-2010, 04:49 AM   #15
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Try a french press. I have used one camping and in the Airstream and it makes wonderful coffee(if you put good coffee in it). Just boil water. Only downside I have ever found it that it takes a few minutes to clean it up.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-21-2010, 07:57 AM   #16
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Us too, we've been using a French Press for several years now. Sure beats percolator coffee.
Ahab is offline   Reply With Quote
Old 11-21-2010, 07:58 AM   #17
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
What exactly does the built-in inverters power in the newer trailers (2006)?
had heard that the Sony TVs were 12 V but mine plugged into a 110v outlet
RichHog is offline   Reply With Quote
Old 11-21-2010, 08:45 AM   #18
Crusty's Avatar
1992 34' Excella
One solution used by many truckers is to buy a 12V coffee maker - though I know it doesn't help you in your current situation. A stop at the next Flyin' J truck stop will yield some possibilities and if you have time you can do even better online. One advantage to doing it this way is that you don't lose the power that goes into heating the inverter - all the power drained from your batteries goes into making the coffee.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 11-21-2010, 08:54 AM   #19
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
TB and RICH
boiling the water and pouring will make better coffee than the elec. coffee maker. have done it many times because the coffee maker took a c***.
noreen&sal is offline   Reply With Quote
Old 11-21-2010, 09:28 AM   #20
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
coffee, inverter
Originally Posted by andyleonard View Post
Not enough and too many, would be my guess. The inverter seems happy to charge the phones and run small stuff, but the coffee maker switch doesn't light up like it should and after about 15 seconds the inverter stops buzzing. I guess maybe I need a smaller coffee machine....or a pot.
Looks like you answered your own question here.
Unless you have a 2000 watt inverter, you will have problems perking a 10-12 cup coffee pot. Battery capacity is then the next limiting factor.
The gas is you only solution. You just have to get up a little earlier. Any other options just don't give you fresh perked coffee!
A Good Morning to you
Dave
Old 11-21-2010, 09:33 AM   #21
2007 25' Safari FB SE
Eureka Springs , Arkansas
I'm the only coffee drinker and have started using a french press.
Heat the water on the stove and in a couple of minutes you have hot coffee.
Found mine on Amazon and another cheaper one at Ikea.
I discovered that the large "6 cup" size is 2 cups by my standards.
triplenet is offline   Reply With Quote
Old 11-21-2010, 09:34 AM   #22
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Think gas
I have been using the Aero Press for over a year and love it.
Cleans up with less water than a French Press
and just as fast.
You'll thank me
AeroPress® | AEROBIE® High Performance Sport Toys
ArtStream is offline   Reply With Quote
Old 11-21-2010, 09:38 AM   #23
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
And don't forget to sprinkle a little cinnamon on top of the coffee grounds before pouring the hot water through.
Once it's finished, simply add Bailey's (a lot!) and it should be ready to drink...
Hibby
Hibby is offline   Reply With Quote
Old 11-21-2010, 09:48 AM   #24
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
and just as fast.
You'll thank me
Thanks Artstream! I just ordered one off of Amazon for $28.90 with free two day shipping, and it came with 350 extra filters (also free!)... We will use this in our Airstream, as well as our cabin an our boat.
GREAT idea!
Hibby
Old 11-21-2010, 09:49 AM   #25
masseyfarm's Avatar
Images: 56
Coffee
and just as fast.
You'll thank me
Always something new!!!
This looks interesting. I am going to look for one. Should be better when running/drinking solo than making a pot and drinking old coffee.
Thanks for the info.
Dave
Old 11-22-2010, 01:07 AM   #26
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I believe the 110 cord to the TV leads to a transformer to reduce the volts...
We can run our TV from the factory inverter...or 110 when on shore power... The inverter will power items that don't draw too much and are plugged into the inverter outlets in our rig.
TB & Greg and Abbey Schnauzer
#3954
Old 11-22-2010, 02:35 AM   #27
2005 19' Safari
GLENDALE , AZ
Check out the Bodum stainless steel, French press: Amazon.com: Bodum 1308-16 Columbia 8-Cup Stainless-Steel Thermal Press Pot: Kitchen & Dining
You can search for a better price, then just pick the size that works for you. We have been using one of these for several years, and they make great coffee.
Old 11-22-2010, 08:33 AM   #28
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
cooking the coffee
Don't mean to take this off topic but I have an old stovetop perculator - school me on how do you actually cook the coffee with a perculator?
We got rid of our automatic drip for a regular electric perculator a few years ago but I would like to know how to use the backup stovetop just in case.
Do you just boil the water for awhile?
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Good coffee maker for a trailer? WineStream Stella's Kitchen 421 10-31-2015 10:08 PM
Inverter to run refer while driving... lilynhoward Batteries, Univolts, Converters & Inverters 26 11-21-2010 02:06 PM
Installing Inverter to run all AC outlets in Airstream Interstate Aahj Batteries, Univolts, Converters & Inverters 6 05-17-2010 07:22 PM
Inverter/Generator Run on LP judybug Generators & Solar Power 1 05-13-2010 08:47 PM
