Old 07-18-2019, 09:39 AM   #1
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Replacing black/gray tank adapters
I'm replacing the two gray and black water tank adapters since they started to crack and leak. The remainder (valves and pipes) are still in good working order. I ordered the two tank adapters from Inland RV and they should arrive some time today. I also ordered two Thetford valve rebuild kits since I needed new O-rings that go between the valve body and the adapters. I also figured this would be a good time to rebuild the valves even though they didn't leak. One question though. What type of sealant should I use on the tank outlets where the adapters go in. I've thought of silicone glue/sealant and I also have some Dicor self leveling lap sealant. Any suggestions on what I should use?
92landyacht is offline   Reply With Quote
Old 07-18-2019, 08:46 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
The ones on my trailer are just clamped in. No sealant.
CRH is offline   Reply With Quote
Old 07-19-2019, 08:04 AM   #3
1992 36' Land Yacht
Grayson , Georgia
Looks like AS did use some form of sealant as both of the adapters that I pulled out of the tanks did have some form of gray coating on them. Since the tanks are nylon and not very compressible I'd feel better having some form of sealant there. Just trying to see what others have used.
Old 07-19-2019, 10:48 AM   #4
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I used silicone and it worked. I read in another thread that Airstream originally used Vulkem.
Waipio Rim is offline   Reply With Quote
Old 07-19-2019, 03:35 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I thought AS used polyethylene tanks and silicone will not stick to poly.
Old 07-19-2019, 03:52 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Use Vulkem (or similar polyurethane)or Lexel.
If you use silicone, next time the caulk may hav adhesion issues.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-20-2019, 09:43 AM   #7
1992 36' Land Yacht
Grayson , Georgia
Ordered the Vulkem 116 today from Amazon Prime. Should arrive by Tuesday.
Once the valve rebuild kits arrive and the Vulkem arrives, I'll be ready for the re-installation of the drain system. I'll try to post picks of the rebuild process but it looks to be pretty straight forward.
Black tank only for gray and black water??? mmollema Waste Systems, Tanks & Totes 9 02-01-2017 04:36 PM
Replacement black tank and new gray tank mingle51 Waste Systems, Tanks & Totes 3 11-20-2015 07:03 AM
Tank level monitor suggestions for new black/gray tank redreefet Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
Anybody know if a black tank will fit in the gray tank space on my TT? Aage Waste Systems, Tanks & Totes 9 02-24-2010 04:13 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
