Old 04-16-2010, 05:52 AM   #1
Replacement water heater, which one?
This seems to be the year to replace everything on the motorhome.
Apparently I didn't winterize properly and our Atwood water heater is leaking from several locations. So...any suggestions on which water heater would be a good replacement?
We want to keep the electronic start feature and have also been considering getting one with an electric option so we can get how water without using propane.
One thing I don't want to deal with is the auxillary heat lines coming from the engine. I plan on eliminating that feature as well as removing the auxilliary heater under the couch.
Any suggestions?!
Old 04-16-2010, 06:22 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Here are three choices (Really two, from three different sources):
Atwood RV Water Heater on Sale
Atwood Water Heaters - Product - Camping World
Atwood 6 Gal Water heater Gas and Electric 80-1350 - $0.00 : ODMRV , Out-of-Doors Mart
Old 04-16-2010, 07:37 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Another source - includes free shipping.
Atwood RV Water Heaters
Old 04-16-2010, 02:51 PM   #4
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Thumbs up Replacement Water Heater
I agree with your reasoning Brad. My choice for w/h is propane & electric. By doing away with the motor-aided w/h you'll find you use less propane when you are parked. The electric does well when you have hook-ups, and can be supplemented with LP if necessary. Doing away with motor-aided gives less opportunity for failure of hoses and other components that could result in an engine melt-down too. Simpler is better. Especially in motorhomes.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 04-22-2010, 02:24 PM   #5
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Brad,
I replaced our water heater a few years ago. Check with PPL Motorhomes. They are in Houston, TX. They seem to have some of the best prices anywhere.
Good luck, Rob
Robfike is offline   Reply With Quote
Old 04-27-2010, 06:09 AM   #6
Thanks All for the replies. Looking at the links above and talking it over with Susan we ended up buying one off of eBay for $400 plus shipping. It is a propane/electric with electronic start. It arrived in 2 days and looks exactly like we wanted. It didn't come with the outside door, nor did it come with the switch for controlling electric/propane option. I found that for $12 shipped via eBay as well.
Now to install it.....
Thanks!
Old 07-09-2010, 04:02 PM   #7
Robfike's Avatar
Speedway , Indiana
Brad,
I had to hijack your thread to send you a couple of pictures of what I am looking for.
You will notice in the first picture that there is a rectangular aluminum end on the black plastic trim to the left. On the right there is only the two pop rivets remaining where the trim end used to be.
In the second picture the green tinted pane is the one I need.
Thanks, Rob
Name:	Airstream trim 002.jpg
ID:	106543   Click image for larger version
Name:	Airstream trim 003.jpg
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 10:13 AM
Water Heater Replacement lebolewis Water Heaters, Filters & Pumps 2 05-13-2009 04:56 PM
Water heater replacement Robfike General Motorhome Topics 24 03-08-2006 02:36 PM
Water Heater Replacement (help) rdm General Motorhome Topics 1 07-14-2003 03:31 PM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 04:53 PM
