Yes ---- on the back side of the dash plate, is a little button near the dash end of the switch that, when pressed all the way in, will release the headlight switch shaft to pull out.
It is probably the standard Ford switch from the 70-80's
Dave
Originally Posted by MarkHerman
I'm new to the Airstream world. Have 1996 MH with Freightliner chasis. Dashboard cracked and piece fell off. Have every thing removed but can't figure how to get the headlight switch knob detached so switch can be removed. Is there a trick?
