Old 08-09-2011, 10:14 AM   #1
Grain Valley , Missouri
Removing dual fuel
I have an old Holiday Rambler that was factory equipped with dual fuel (gasoline/propane). Parts of the propane system had been removed or damaged before I got the motorhome so I decided to just remove the whole thing. I thought it was just a simple matter of disconnecting propane lines and removing the regulator that was behind the front tire. However, I discovered that when I cut through one of the hoses, I got engine coolant running out. I then wondered what have I done. Soooo I tried a search on iRV2 forum, rv.net forum, and Airforums. Didn't find any information on the first two, but found just what I needed on Airforums. Seems someone had done the very same thing on an Argosy and I found out that there is an evaporator that is heated by the engine coolant. So, I hadn't cut into something I shouldn't have. I feel a lot better now. I never thought there would be engine coolant as part of the propane system. Thanks Airforums for putting my mind at ease.
QuietWater is offline   Reply With Quote
Equalizer vs. Reese dual cam road test dznf0g Hitches, Couplers & Balls 25 08-02-2011 07:30 PM
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 10:47 AM
Reese Dual Cam help.. Janie Q Hitches, Couplers & Balls 2 07-06-2011 01:06 AM
Extra fuel tank line? pdallas Classic Motorhomes 4 05-12-2011 10:32 AM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 10:18 PM
