09-09-2007, 09:16 AM
Richmond
, Kentucky
Is this a reasonable hydraboost replacement price?
Last Thursday afternoon I dropped our 310 Motorhome off at a local truck repair shop to have them check the tires to see if any were out-of-round. While there we decided to have them replace the brake master cylinder because it had started leaking on our return trip from PA in July.
This shop runs a night shift that ends at 11 pm and the shop foreman told me if I brought it down by 5pm Thursday that night shift would do the work and I could drive it home that night. Well after the mechanic looked at the brakes he decided the hydroboost was bad, not the master cylinder. At the time I didn't think much of it, I just assumed the mechanic would be right. Due to difficulties in getting the hydroboost removed the job didn't get done on Thursday night. I told the mechanic not to rush it and that we would just come by Friday around noon to pick it up. I also told him to go ahead and replace the brake master cylinder while he was in there doing the work.
Keep in mind the original reason we took the Motorhome to them was to get the tires checked for out-of-round. Well we got a call from them early afternoon on Friday and they informed us that they had installed the wrong master cylinder and could we pick it up Saturday afternoon instead.
Oh yeah, each time I talked to these people I asked how the work on checking the tires was going and each time I got the response that checking tires was "day shift work".
Well I went out to pick it up Saturday afternoon and found that the bill for replacing the Hydroboost and the master cylinder totalled $988.
When I asked how much of that was for checking the tires he informed me they didn't do that, it was "day shift work" and apparently the Saturday crew couldn't do it. Needless to say I was extremely
The parts cost totalled $375 for the hydroboost and the master cylinder. I'm assuming those prices are in a reasonable price range. However we were billed for 9 hours labor because they had a hard time getting the hydroboost removed. It seems to me that 9 hours labor is somewhat excessive for replacing these two components, especially since you have to remove the master cylinder to get to the hydroboost anyway.
Needless to say, I refused to pay the bill and told them I would be contacting the service manager about the price and the fact they didn't even bother checking the tires (which was the main reason for taking the motorhome to them anyway). When I complained to the clerk that they didn't even look at the tires the clerk politely pointed out that they didn't bill me for checking the tires
As far as the mechanic deciding the hydroboost was bad I'm not so sure about that one. When the brakes started to fade during our return trip I checked the fluid in the brake master cylidner and found it low and also checked the power steering (hydroboost) fluid and the level was just fine. To me that sounds like the brake master cylinder was leaking, NOT the hydroboost. Braking action was very good as long as the master cylinder had sufficient fluid in it.
So, is 9 hours labor reasonable for the work done? And should they have even replaced the hydroboost?
Oh yeah, during the time that the motorhome was in their shop I mentioned to no less than 3 different people (including the service manager) that we really needed to find out which if any tires were out of round.
1975 24' Argosy Motor Home
09-09-2007, 09:36 AM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Oh man, Brad! I’m sorry. That certainly sounds like a lot of time to me. I believe I’ll avoid those guys like the plague.
Vaughan
09-09-2007, 11:36 AM
1982 28' Airstream 280
Norfolk
, Virginia
Brad,
Steven Webster has a great thread about this topic in the Mechanics Corner area. It should give you some idea of how long it should take to do this job.
I had the same symptoms with my MoHo and all I did was replace the mc and all was well.
Did the shop save the hydroboost they took out and show it to you?
Steve
09-09-2007, 12:52 PM
1978 31' Excella 500
Venice
Sounds like someone got "boosted".
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
09-09-2007, 02:18 PM
Richmond
, Kentucky
Steve,
I read through Steven Websters posts a while back. Definitely not an easy task, but for a service shop I would think it would be a "little" easier.
For some reason I thought I saw a reply from Overlander63 (Terry) here a little while ago but it seems to be gone now.
He commented about whether it was more than $50 over the estimate. Unfortunately I didn't get an estimate on the repair job. My biggest problem is I'm too trusting when it comes to this sort of thing
I plan on having a long conversation with the service manager about the whole affair.
I'll update this thread tomorrow.
09-09-2007, 03:45 PM
1967 26' Overlander
Huntsville
, Alabama
I doesn't help now, but
FWIW, in the future ask about the "flat rate" on labor for future service items. There are companies whose only business is to determine this stuff & publish it.
9 hours labor is a half-day's work for two technicians. Terry will have a better response (if he sees this post) than I will, but if the business does not make a habit of working on motorhomes, they will have a learning curve with each job.
Tom
09-09-2007, 03:55 PM
1984 31' Airstream310
Central
, Ohio
Yeah, we were pretty astounded when we got the final bill. The only thing I could think of was in all of the confusion between day- and night-shifts that we got charged for the time they spent putting on and taking off the wrong master cylinder. Hopefully Brad will get it all straightened out tomorrow.
We were also surprised to hear them say the hydroboost needed replacing, and they did not give Brad a reason why. We went ahead with it since we figured it was best to have two totally new parts that we knew the history of in there.
There's always something, isn't there. Sigh.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
09-09-2007, 04:13 PM
1960 24' Tradewind
santa barbara
Hey there Brad ,
The first thing that should always happen is to get an estimate in writing
or a verbal estimate ,noting the time and date of the verbal authorization.
Im an automotive mechanic /technician by trade ,and I give both types .
If the price for any reason should change or more parts are needed ,which
happens often ,you the customer need to know how much .The written initial
estimate is most critical ,the BAR can come down hard on any shop for
failing to do just that .did the shop not give you any idea of how much the repairs would cost? The shop can go off a" flat rate "or "book time"for your vehical so as to give you a proper cost of the repair .In any event ,if the
estimate will exceed your authorization initially ,no work can go forward
without your futher authorization of how much more it will cost ,written or verbal .If you signed the work order for the price you are being charged however ,your stuck with it .Always check your copy that you sign to ensure
that it clearly matches their copy and no charges were written in to make it appear you signed .
Ok ,then good luck
Scott of scottanlily
09-10-2007, 06:14 PM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Stop !
Heres where and how the Hydra Boost looks.
Would be easy to tell which was leaking...Master or Hydra by the smell, color and feel of fluid.
Hydra would be power steering fluid, red, oily and sweet smelling
Master would be clear to carmel, dry feeling and sharp salty smelling.
This is how a simple Master replacement turned out.
All parts were found in stock at Advance and NAPA...I was shocked.
Total was $240 +/- that was for,
Master Cyl
Pads
Calipers
Flex Hoses (the sorce of all evil)
Try to slip something past the Inspector...
Heres the Booster...not so tough to get to
This hose is what caused all my problems.
It would let fluid go to calipers when you hit the pedal, just would not release pressure when you let off.
That caused brake pads to constantly push in on rotor, until failure.
I did not find out until starting to bleed system...would not drool when left open.
09-10-2007, 06:51 PM
Retired.
, At Large
I did post a reply earlier, but it wasn't very nice toward the repair shop, and I couldn't make it nice, so I deleted it. A master cylinder and Hydroboost unit should take about 3 hours to replace. If they charge flat rate, there should be a set amount to perform this repair, and the mechanic is on his own as far as learning curve. If more materials were required (torches, screw extractors, etc) that should be listed separate. What it SOUNDS like happened, is the guy working on it buggered up the hydro unit trying to replace the master, and they replaced it, and charged you for it. He could have, for example, snapped off a rusted master cylinder mounting bolt, rendering the unit useless.
09-10-2007, 07:05 PM
Richmond
, Kentucky
Master Cyl
Pads
Calipers
Wow, your prices are almost unbelievable (I said almost ).
I don't know that I've ever seen brakes that looked that bad before. I bet towards the end you heard some squealing.
Thanks for the pics.
09-10-2007, 07:12 PM
Liberator
1972 Argosy 24
Heart of Dixie
, Alabama
Have the prices, part #'s and which store somewhere...
Calipers $75 each
Pads $35
Master $35
Hose...this I can't remember, either $11 or $30, did Eldorado about same time.
Returned all my cores, and did lots of web site price checking.
Is very important to get correct P30 brake system, and will have to go dig this # up...caliper is what gave correct system number by matching part to part, this took two trips of course.
All parts were rebuilt too, (except pads and hose) get new and price triples.
09-10-2007, 07:19 PM
Richmond
, Kentucky
I knew you had replied because I still had the browser window open that had your reply. When I used another window to check on the thread again your post was gone so I went back and looked at the still open browser window and there it was.
I talked with the service manager today and things are a little better. He apologized for the labor charge and said they are a flat rate shop and while I was on the phone with him he tried to find the rate for the brake/hydroboost repair. He couldn't find it and had to make a few calls. He then called me back and said the flat rate charge was 4 hours. Much better than the 9 hours the Saturday clerk tried to hit me for. The shop rate for motorhomes is $84/hr so the labor should to be $336. I say "should" because we haven't seen the bill yet.
Remember the real reason we took the motorhome to them, to check the tires for out-of-round.........well guess what, they still hadn't done that when I talked to the service manager this morning. However he said they would take care of it today. So when he called me back this afternoon (which is when he informed me of the 4 hour flat rate) he said they checked the front tires and they were slightly out-of-round but couldn't really check the tires on the rear because they couldn't spin them fast enough (highway speeds). I got kind of irate at this and suggested that maybe he could move the rear ones to the front to CHECK them He decided they could do that and would get back to me tomorrow with the results.
I can't believe its been this hard to get it through their heads that we really do want all of the tires checked
Oh well, maybe tomorrow we really will know about our tires
09-10-2007, 07:33 PM
Richmond
, Kentucky
Calipers $75 each
Pads $35
Master $35
Definitely good prices. Was this a front brake only repair or did you replace the rear calipers as well?
So far on our coach we've replaced all of the rubber lines, hydroboost and master cylinder. I've looked the pads and rotors over and they "appear" to be in good condition. I will be checking them closer in the next few weeks, definitely before our trip to Branson in October.
Thanks for the info!
09-11-2007, 06:51 PM
Richmond
, Kentucky
Well no news to report today. After talking with the service manager monday at 4:30 pm he told me they would check the tires on tuesday (today). Well I waited until 4:00 pm today to call and see what they found out and guess what, no one looked at the tires
Turns out the service manager called in sick today and apparently didn't leave instructions for the tuesday day shift crew. So I'll be talking with him in the morning to see if we can't get something done.
You would think that a service company that has about 16 service bays for large trucks would be better organized than this
I'll keep ya'll posted if or when we hear more.
09-11-2007, 06:59 PM
Retired.
, At Large
Send in the clowns...
Is there another shop you could take your motor home to for the tires?
Sorry, anyone that knows me knows I have a low tolerance for the kind of thing you are going through.
09-11-2007, 07:23 PM
Richmond
, Kentucky
Terry,
I haven't really checked around as yet for another shop. But now that you mention it, it might not be a bad idea to see if some other shop in the area can check tires for out-of-round.
The service manager was so upbeat about checking the tires when I first contacted him I thought we had finally found a decent service center.
We'll see how the dust settles when its all over.
Thanks for the suggestion.
09-12-2007, 06:15 PM
Liberator
1972 Argosy 24
Heart of Dixie
, Alabama
Go Merry
There is an older tire shop in town that used to do recaps...
They have a machine for truing up out of roundness.
Is like a giant razor blade and the tire in on a spinner/lathe.
Shaves off thin slices of rubber.
So, maybe look for a tire shop that has been around a long time.
09-12-2007, 07:24 PM
bkalher
Do you have stock steel wheels or aluminum?
It will be great to have another MH at the Branson Rally.
09-13-2007, 06:54 AM
1984 28' Funeral Coach
Belleview
Wow, what an ordeal. I'd be gone outta there with your rig ....fast. Leave the tire work to a truck tire shop.
I'd want to see my old parts before settling up on the bill. The four hour rate is not all that bad. I'm one who would not want to tackle this on my own and would gladly pay the hourly rate to have someone else do it.
To often folks just sign the check and depart without comment.
Now the real problem as I see it is the low MC. Sounds like they didn't bleed the system after installing the MC. How is the braking action now?
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
