Old 12-21-2009, 11:44 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Rear Monitor & Camera Advice
Has anyone pulled the rear camera from your motorhome? I ask because mine stopped working and I'm told by RVCAM folks they would test it along with the monitor that is just rolling horizontally, if I send it to them.
When I suggested that I would need to cut the cable since it is hard wired to the camera, they stated that I should just pull the cable out about two feet or so and there would be the connector at the end of that stretch.
Has anyone done this? Seems like it won't be an easy task, and from just looking at where the cable enters, not much room for pulling out a connector. Your advice would be appreciated. Thank you.
Steve
spat61 is offline   Reply With Quote
Old 12-21-2009, 07:18 PM   #2
maltnhops's Avatar
1989 34.5' Airstream 345
Strafford , New Hampshire
Send a message via AIM to maltnhops Send a message via MSN to maltnhops Send a message via Skype™ to maltnhops
Steve,
I may not be of much help because I haven't actually removed my camera. I was curious about the idea of replacing the bulky B/W camera with a newer, smaller color unit. In my '89 345LE, I have a bulkhead cabinet with two tambour "garage doors". In the middle inside the cabinet is an access panel. I pulled the panel and I could see where the camera housing bolts in place. I didn't see a cable connector in there, but it would certainly be easier to pull it from this area as opposed to pulling from the outside. Of course, you may not have the same interior configuration, so this may not be of any use at all.
I look forward to hearing how this plays out for you.
Good luck!
Wally
'89 345LE Classic Motor Home
'55 Flying Cloud - sold
'61 Bambi - sold
'66 Caravel - sold
'64 Safari - sold
www.vintageairstreamer.com
www.classicairstreammotorhome.com
maltnhops is offline   Reply With Quote
Old 12-22-2009, 03:09 PM   #3
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
I had to replace our original camera system a few years ago. I gained access to the wiring harness at the camera from inside the rear upper bin. I only needed to use 4 of the original 14 wires that go up front. I just picked the 4 I wanted to use, and then connected them in the back and the front. Works great. I just went with the cheaper black and white new unit.
Rob
Robfike is offline   Reply With Quote
Old 12-22-2009, 05:12 PM   #4
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I had a problem with my back-up system. A repair (I use that term loosely) shop I took 'Silver Bullet' to get the front-end aligned couldn't get her to start and somehow (probably reversed the charger/jumps leads) blow the battery up and burned the starter up. Later I found the wiper control burned up, radio out and the back-up camera's 12v to 24v inverter bad. Can't think of the brand.... RG maybe. Anyway it's out of business. Couldn't find a replacement. Had to invert 12VDC to 110VAC, then 110VAC back to 24VDC. All of this in the dash. The duel wiper control isn't made any more, but it was easy to repair: replace the reverse polarity diode (cue to what the cause was) and replace the smoked lands on the control board with wire. Replaced the radio too.
They also broke the window latch on the drivers side. They said, "That thing is old, you got to expect things will break."
Tried BBB, that was a joke.
If I can't fix it myself, maybe it didn't need to work.
There, my repair shop war story from Edmond, Ok.
mel
choctawmel is offline   Reply With Quote
Old 12-23-2009, 08:46 AM   #5
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Two years ago ours quit. I got on the internet and found a new one for about two hundred fifty dollars. This one is a color system with night shot as well. I hooked it up using the original wiring and rear bracket.
I wouldn't try to repair the old one. Get something modern.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 12-23-2009, 01:12 PM   #6
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
There are no end of CCD mini cameras that you can feed to a monitor or better yet an LCD 7" stereo screen on the dash. You can clear the dash of the monitor and let the camera hang in the rear window out of the weather. Just be sure the camera you pick has a dip switch array that allow you to mirror the image.
What you get is very low power consumption, an inside mount, and a cool new stereo all in one very nice upgrade problem solving fix.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 12-23-2009, 09:35 PM   #7
spat61's Avatar
Rear Camera
Gunner,
Can I impose on you to elaborate on your installation and especially the brand your purchased that works withn existing cables. A couple pictures of your dash setup with also be greatly appreciated. Thanks.
Steve
Old 12-23-2009, 09:37 PM   #8
spat61's Avatar
Gunner,
Steve
Old 12-24-2009, 01:43 PM   #9
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I'm color blind and deaf, so $40 to fix the original equipment works good. That leaves me $160 beer money.
Sure wish I'd leaf for New Orleans already. The snow and sleet is going sideways in the 50 mpg wind outside. Leaving Monday for sure!!!!
mel
Old 12-24-2009, 02:59 PM   #10
The Hawk's Lair
cooperhawk's Avatar
Originally Posted by spat61 View Post
Gunner,
Steve
Sorry, been plowing snow all day. Big storm!
Have to get back to you. Motorhome is in shed and not really accessible right now. I thought I posted some pics a while back of the setup but I can't make the search work for me.
AKA THE GUNNER
VFW, LEGION, NRA
Old 12-25-2009, 06:12 AM   #11
GlenCoombe's Avatar
Belleview , Florida
Images: 27
I was cruzin' eBay and found a 10" rearview mirror replacement that's a monitor.
Innovatek 10.2" CAR REAR VIEW MIRROR LCD SCREEN MONITOR - eBay (item 320465701892 end time Dec-24-09 20:47:38 PST) though this one ended there are lots of them from Hong Kong to Canada.
Couple this with a CMOS or CCD camera with IR LED's for night viewing and you've got a very capable system without getting the new stereo.
Old 12-25-2009, 04:50 PM   #12
Ottawa , ON
It's been pulled, for some reason...
Old 12-26-2009, 07:16 AM   #13
GlenCoombe's Avatar
Belleview , Florida
Images: 27
I went back and pulled a US shipper on a complete system for you to look at.
10.2" Rearview mirror monitor + Water Proof Camera + TS - eBay (item 370305376038 end time Jan-10-10 09:36:42 PST)
If you're looking for options just search rear view camera or monitor and you'll have lots to look at.
FYI I don't know anything about this product but that it is a solution for dead cameras and cluttered dash boards.
Safety Camera/LCD Monitor Muddy Waters Audio, Video & TV 8 01-25-2009 11:43 AM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
Sony Rear View Camera gunworks Electronics & Connectivity 1 10-08-2005 01:27 PM
Backup Camera monitor Save$$$ GlenCoombe Classic Motorhomes 8 08-08-2005 02:49 PM
