Old 01-30-2005, 01:05 PM   #1
1976 31' Sovereign
Youngsville , North Carolina
Images: 8
Random Electrical Discharge [A/S 325]
Hello All,
First off, this is not my A/S, I'm helping a friend fix it who is in the military and is traveling too much to work on it so bare with me. I don't have the A/S or the manuals right in front of me but I think someone on here will recognize this problem quickly....I hope.
We're having trouble with a 1985 A/S 325 in the electrical system. The A/S is having an intermittent electrical system discharge while driving/running.
Driving down the road, the A/S dash mounted volt meter would go from charging to discharging every few minutes and stay on the discharge side for roughly 30 seconds. Got the A/S home and parked it and it sat for a month or so. Came back to it and the batteries were completely dead...not surprised though.
Put the A/S on the charger to get the A/S running and used the wiring diagram to begin troubleshooting. With the A/S running (ideling or at speed) you could watch the meter jumping from chare to discharge. Under the hood you could hear a clicking. Found the clicking and it was a 30A breaker according to the manual. Replaced the breakers and the batteries (all three) and the problem is still there.
With the drastic change from charge to discharge, it appears to me that it is caused in something that is completely failing. I.E. the Isolator or a switch somewhere. I didn't get to spend much time troubleshooting everything on the A/S because it was getting dark and it's a 9 hour drive each way so I made my best guess and I was wrong. I would really appreciate and educated guess from everyone on here before I make that trip again.
Sorry this is so long but I wanted to give all the details possible and once again...thanks in advance.
Josh
Fish36991 is offline   Reply With Quote
Old 01-30-2005, 04:38 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you could try disconnecting the isolator and see if that changes anything while your vm is on it, at least then you would know which circuit the problem is in, the chassis or the house.
It could be a faulty alternator or regulator or both. What is the charging rate when its working right?. Is there a short in one of the batteries?. Just a few places to start checking, before you get into wiring shorts, etc.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-30-2005, 05:14 PM   #3
LOST , Hawaii
What alternator? Was it a breaker or relay clicking?
John
74Argosy24MH is offline   Reply With Quote
Old 01-30-2005, 05:17 PM   #4
1976 31' Sovereign
Images: 8
I know the batteries are okay because we replaced them all and I checked them without the load of the A/S on it. The altenator is putting out around 14V so that should be good. I don't know if it's momentarily dropping voltage but I've never seen that before on any alt. I noticed on the schematics that there is some kind of switching system behind the batteries on the pull-out tray. I'm thinking it's in there or in the isolator. Hope that info helps narrow it down. Any ideas?
thanks by the way for the response.
Josh
Old 01-30-2005, 05:20 PM   #5
1976 31' Sovereign
Images: 8
It was a breaker according to the schematic.
This may help. It's located directly in front of the steering wheel under the hood and is panel mounted to what appears to be a firewall. Standing in front of the A/S it's probably 5 feet up and 1.5 feet from the driver side of the A/S. The schematic called it a breaker...if it would have described it as a relay, it would have been on the top of my list to replace due to seeing MANY relays fail over the years.
Josh
Old 01-30-2005, 06:44 PM   #6
1976 31' Sovereign
Images: 8
Also, The owner of the motorhome said there is a airstream motorhome boneyard somewhere in Alabama...has anyone heard of this? If so, please let me know because this may be a good source for parts. Anyone know of any other place to find parts for the Airstream 325? Thanks so much for everyones help.
Josh
Old 01-30-2005, 07:25 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Thumbs down A short
If it is in fact a breaker cutting out, it is because you have an overload or short in that circuit. Check to see what doesn't work in the coach, then start unplugging items in that circuit until the breaker stops tripping, when it does, you have found the problem. It could be a mouse has chewed a wire that is now touching bare metal.
Old 01-31-2005, 07:01 AM   #8
1976 31' Sovereign
Images: 8
Would the breaker "chatter" like that if there was a hard short or a constant overload. I would think it would just stay open and never reset itself....not sure though. I really don't know how the circuitry in an airstream works or what failsafe systems are in place. That is another possibility added to my list to check though. Thanks. Any other ideas?
Josh
Old 01-31-2005, 07:25 AM   #9
LOST , Hawaii
That is why I wondered if it was a breaker or relay. Even self resetting breakers usually take 15-30 seconds to reset. Argosy20 probably gave you the best advice, start following the circuit it protects. You have a schematic so that will help, keep an eye out for previous owner mods, they are not always the best.
John
Old 01-31-2005, 10:49 AM   #10
1976 31' Sovereign
Images: 8
The schematic called it a breaker but I honestly can't tell you. The more I read on here it seems that there are few "common" electrical problems. Every A/S has it own little demons here and there that have to be hunted down and taken care of...and I guess this one is no different. There is no difinite right answer when it comes to troubleshooting so I guess I need to accept that it may be me, the airstream, schematics, and my meter spending some quality time together but let me know if something else pops in your head.
You guys have offered some great places to look and for some non-common things to look for. I really appreciate all the help and advice. Since this isn't my A/S I don't know how much I'll be on here in the future but I promise to post the results of the repair on here for everyone so maybe it will help the next guy.
Thanks again everyone, Be safe and I'll report back soon (might be as long as a month),
Josh
Old 01-31-2005, 01:32 PM   #11
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I know the batteries are okay because we replaced them all and I checked them without the load of the A/S on it. The alternator is putting out around 14V so that should be good. I don't know if it's momentarily dropping voltage but I've never seen that before on any alt. I noticed on the schematics that there is some kind of switching system behind the batteries on the pull-out tray. I'm thinking it's in there or in the isolator. Hope that info helps narrow it down. Any ideas?
Josh
If it's the standard gage on the dash for the Alternator they by GM's wiring that should be before any of the motor home wiring. If its not the alternator then there is a dead short happening and overloading the alternator.
Connect a VOM to the lug on the back of the alternator and see if you see the voltage drop there. If you see drop there then check the wire going to the side of the alternator (usually green). That is the Field wire. It excites the alternator into charge. It gets 12v from the battery when the ig is turned on. Verify its not losing power.
If no drop on the Field circuit and still having the drop on the charge then see if you can get the rest of the non engine related load off and see what happens.
Check the battery cables as well. GM wires in two variations. On some the main cable from the battery will hit the harness feeds for Alternator, Fuse box and starter at the starter. There will be fusible links at that point. In most HD Alternator arrangements there will be a wire directly off the Alternator to the battery instead of joining at the Starter. If it is the Later set up then it is possible that the wire from the battery to the alternator could be corroded and causing these symptoms.
If all that tests out then pull the alternator and have it load tested.
To me it sounds like the Alternator. Last one I had fail had similar symptoms where it would just stop charging.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-01-2005, 03:48 AM   #12
1976 31' Sovereign
Images: 8
Thanks 59Toaster, (great name by the way)
That gives me a step by step to check this thing out as well as everyone elses suggestions. This should definitely give me a good starting point so I can dive right in as soon as possible.
I really appreciate everyones help, it makes me want to go buy an airstream if the community is this nice. I have a Harley and ya'll have their forums pretty much beat. Anyway, thanks again to everyone and I'll report back and let you know what I find...I'll also let you know if the airstream beats me again!
Josh
Old 02-01-2005, 05:04 AM   #13
1984 31' Excella
Norfolk , Virginia
Images: 11
Have you repaired the problem? If not Take a picture with a digital camera of this 30 amp relay and email it to me so that I can identify it. Also sent any numbers or letters.
Beginner is offline   Reply With Quote
Old 02-01-2005, 06:07 AM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
if the alternator is the problem, your buddy might consider getting a higher amp unit for the replacement. Once you determine if that is it, let us know I can suggest a good source for one not too expensive.
AIR #005
retired!
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
