Old 02-02-2005, 09:29 PM   #15
1976 31' Sovereign
Youngsville , North Carolina
Images: 8
Alansd,
Funny you said that, I'll be heading down there next weekend and I wanted to see where we could get a replacement alternator to try and keep as a spare if that isn't the problem. I think that may be one of the hardest thing to get to the airstream on short notice. PLEASE, let me know what you guys suggest for a replacement alternator.....Thanks so much.
Beginner, I can't get pics of the 30A breakers he replaced becasue the airstream is in another state and he's not in either state right now. We'll both be flying in next weekend to try to resolve this problem. I'm 99% sure that the schematics referred to them as breakers and I'm 100% sure that I was on the correct component that matched with the schematic. When he took them into the shop to get them replaced, the employees at the shop even referred to them as breakers so I'm pretty sure they were not relays...at least not called relays in the manual.
I can tell you were they were located. If you were standing in front of the 325 and you have the drivers side headlight pointing at your chest...they are just to the left of the light, under the hood. I don't have the schematic but I do remember that the one that was clicking (chattering or just resetting every 30 seconds) was tied into some switch/selector that I think was located behind the batteries in the tray. The way the tray is built, it was difficult to get in the back side of the tray so I just probed at the other ends of the wires that were connected to the switch/selector.
I know this is long but that's about the best I can recall...if you have any questions, ask away...it may refresh my memory on some more details. Thanks again guys,
Josh
Fish36991 is offline   Reply With Quote
Old 02-03-2005, 04:29 AM   #16
1984 31' Excella
Norfolk , Virginia
Images: 11
Instead of continuing to shotgun the problem, just look at the offending circuit. First determine which circuit breaker is clicking. This can be done with a digital voltmeter or even a light bulb with two leads. If interested, reply and I will go through the process step by step which will allow you to isolate down to the shorted item.
Beginner
Beginner is offline   Reply With Quote
Old 02-03-2005, 06:53 AM   #17
1976 31' Sovereign
Images: 8
Thanks beginner,
I'm not too proud to ask for more help. Any procedure for troubleshooting on the airstream would be great. I'm good with electronics but finding the locations of all the components listed on the schematic is not cut and dry. Board troubleshooting is much easier because all the components are in one place...on the airstream, they're everywhere. Thanks again,
Josh
Old 02-03-2005, 08:14 AM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I got my alternator through www.4alterstart.com I bought the 135 amp version and it has been pumping out the juice for 18 months or so. Good service form them also. It was a fairly easy install.
Since I went to the higher amp alt, I also replaced the battery isolator with a higher amp version. These guys sell the standard alt as well.
I bought their starter first, which solved the hot start issues.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-03-2005, 08:31 AM   #19
1976 31' Sovereign
Images: 8
Where did you get the high current isolator if you don't mind me asking? Thanks for the alternator info,
Josh
Old 02-03-2005, 12:22 PM   #20
1984 31' Excella
Norfolk , Virginia
Images: 11
I can help you with the electrical part.
1. Determine which circuit breaker is opening and closing. This can be done with a digital voltmeter or a light bulb with pigtails. I generally use a light socket from a car tail light or parking light.
A. The circuit breakers that I am familiar with have two posts or threaded studs onto which you place the the two wires, The feed and the load. If you place the multimeter across these terminals (meter range 12 volts DC or better), you will see verry little voltage, usually less that 500 millivolts (mils). If you are using the light bulb, the bulb will not be lit.
B. Start the engine and witness that the charge/discharge cycle is still occuring. As you stated before you heard a clicking that corresponded with the amp meter going from charge to discharge.
C. Try to determine which circuit breaker is clicking by sound if possible. Then test each of the suspected circuit breakers by puting the mulitmeter across the terminals of the circuit breaker. The breeaker that is making and breaking will give you an indication of very low volts then 12 to 15 volts (I hope). Using the light bulb, it will blink on and off. The breakers that are not opening and closing will indicate 0 volts or at least less than one volt/thre light bulb will be out.
D. Once you have determined which breaker is cycling, turn the vehicle off. With the light bulb or the meter check the offending breaker to see if it is energized (hot) with the vehicles key off.
1. If it is not energized remove the LOAD wire. If there are a number of breaker in a row, one terminal the has one or two wires connected to it and the other terminal probally has a metal strip (buss) connecting it to other circuit breakers.
2. If it is still energized, remove the negative battery cable from the battery.
Now remove the LOAD wire. If there are a number of breaker in a row, one terminal the has one or two wires connected to it(the load) and the other terminal probally has a metal strip (the feed buss) connecting it to other circuit breakers.
E. Replace the negative battery terminal if removed and start the vehicle. If the problem has gone away, you have identified the offending circuit. If the problem is still there go through the preceeding steps until you identify the offending circuit and remove the load wires and retest(start vehicle). Next comes the fun part. Figureing out what that breaker feeds. Follow in the vehicke schematic where it goes of follow the harness and see where the wire connected to the circuit breaker leaves the harness and follow it to the appliance that it feeds. Good luck, Good hunting. Let me know how you do.
Old 02-03-2005, 03:45 PM   #21
1976 31' Sovereign
Images: 8
Thanks Beginnner,
Trip has been moved up to this weekend, I'll be flying out tomorrow to the location of the airstream. I'll try this out and let everyone know how it goes and what I find. I've set aside several days to troubleshoot it. Already spoke to the Alternator/starter shop and will be ordering very soon....thanks for the info on that one.
Also, anyone know where to pick up the high current isolator?
Beginner, I was thinking...correct me if I'm wrong. I should also be able to find the bad circuit by placing the meter in parallel with each breaker. When the breaker is in the on (normal) position, no current will flow through the meter because through the breaker will be the path of least resistance. When the breaker kicks open, the current will then flow through the meter and register on the display. Since you have to read current in series with the circuit, the breaker would create the open for you and allow all current to flow through the meter. Second thought, that may blow the fuse in the meter. But, I would trade a fuse to make sure I had the right circuit. Just a thought.....anyway, maybe the light bulb is the better way to go.
Thanks again, I'll be offline tomorrow around 2PM EST so anything you guys can think of between now and then, post away.
Thanks to everyone...I don't know for sure but this has to be the best airstream forum on the net!
Josh
Old 02-04-2005, 05:24 AM   #22
1984 31' Excella
Norfolk , Virginia
Images: 11
Symantics. The term I used "across" meant in parallel. A volt meter has very high internal resistance. Ths minimum internal resistance that I have run into is 20,000 ohms. At that resistance only .0006 amps (.6 milliamps or mills) will be allowed to flow through the volt meter. If you have a digital multimeter the internal resistance is higher. My Fluke 87 runs about 1 million ohms which will allow only 0.000012 amps (.012 mills) to flow. Now if you select amps on your multimeter, I promise you that you will blow the internal fuse as most are capable of carring only 10 amps. The circuit breaker that is making and breaking is rated at 30 amps.
The low voltage that you will be reading when the breaker is "made" is the voltage developed across the contacts. It will hopefully be less that 1 volt or the contacts are damaged. Usually when 10 amps at 12 volts is conducted across a set of contacts you will get at most a few millivolts. This voltage which is developed across the contacts at a known current is the only easy was to calculate the point contact resistance of the contacts because the resistance is to low to be accurately measured by even a good multimeter.
First I learned the correct way to measure things (electrical). Then on that Sunday night, forty miles from nowhere with no tools I figured out methods of troubleshooting with no handy dandy test equipment.
Any way, when you determinewhich breaker is making (on or closed) and breaking (off or open) you will be well on your way. Follow the wire, start disconnecting the items fed by that wire.
If you use the light bulb, connect one side of the bulb to the + terminal of the battery and the other side of the wire that you have just removed from the circuit breaker(load). The light should come on. When you remove the appliance that is shorted or drawing too much current, the light should dim or maybe even go out.
Measure voltage between the - post of the bttery and the disconnected wire. It must be 0 to prevent damaging your meter. With the meter set on RX1, connect one lead to ground (- post on battery or the metal framd of the vehicle) and the other end to the disconnected wire. You should get a low resistance value. When you disconnect the offending appliance, the resistance should increse dramatically.
Good Luck/Good Hunting
Let me know what you find.
Old 02-04-2005, 09:56 AM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The isolator I bought off Ebay. It was new and unused. There are many available online.
Mine is the same brand as my old one, (which I then sold on Ebay) a Surepower I think.
Ended up with a new more powerful one for very little outlay.
The ones at the auto parts stores are too low rated.
AIR #005
retired!
Old 02-07-2005, 05:35 AM   #24
1976 31' Sovereign
Images: 8
UPDATE: We've found the problem!!!!
Guys,
First off thanks for all the help. I found the problem in about an hour and a half but the crazy part is it wasn't anywhere I thought it would be. But here's the update as promised.
It definitely was a 30A breaker that was clicking and in 30 second intervals which is exactly the amount of time ya'll said it would take to reset. I replaced all threee breakers under the hood that feed the three main circuits after the isolator (isolator checked out good by the way as well as the alternator). I have a Fluke 83 and I knew it could measure over 10A for a short time anyway before I blew my fuse...so I measured it. It measured 39A when the 30A breaker would open so I knew I was in the right place....one fuse down. Replaced fuse (I planned for this). Went through the schematics and three things run off this particular fuse: Driver side power seat, Passenger side power seat, and the Air Ride System. The driver side seat is screwed up and I just knew that would be the problem so I disconnected it...problem remained. Disconnected the passenger seat....problem remained. This left the air ride system so I disconnected the air ride system and reconnected the seats and it was fine...even when moving both seats. Measured the current through the air system with the meter...definitely the problem...second fuse down. Replaced fuse.....again.
Air Ride System:
The strange thing about this system is it was running sometimes and others it wasn't. I pulled the schematics for this and read the theory of operation...simple enough. Verified a good ground before going any farther... verified good. Disconnected the three wires running to the pump itself (two grounds and one hot 12VDC). Reconnected and the problem was gone so I thought the pump was going out and pulling WAY too much current but I wanted to verify the rest of the circuit while I was there so I did. Verified the 12VDC directly from the breaker under the hood (good). Verified the 12VDC coming in from the ignition when the key is turned to the main relay (good). Made sure the relay was switching over to turn the pump on and the correct voltages were being applied to the pump connections (good). Verified the low pressure switch operation (good). That covered the entire system except the pump so I used jumper cables to a battery to fire off the pump. I would turn and pump air but you could tell it wasn't smooth and or consistant like it should be...you could hear it's RPMs go up and down. Connected the meter in series to the pump to measure current....problem found...third fuse down. Replaced fuse.
We pulled the pump and he's ordering an replacement today from and airstream dealer in TN so that should get him back on the road. He was also very happy with how solid the voltmeter on the dash was without the random loading going on. The Airstream should be back on the road 100% by the end of the week.
I know I went into alot of detail but maybe it will help someone else. Thanks for everyones help!
Josh
Old 02-07-2005, 06:47 AM   #25
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Fish36991
...would turn and pump air but you could tell it wasn't smooth and or consistant like it should be...you could hear it's RPMs go up and down. Connected the meter in series to the pump to measure current....problem found...third fuse down. Replaced fuse.
We pulled the pump and he's ordering an replacement today from and airstream dealer in TN so that should get him back on the road....
Josh:
It may well be the pump, but consider one other thing....
there is a back pressure valve (check valve) on the top of the volume tank..
the pressure sensor for the high pressure shut off for these units comes off of the tank....downstream of the check valve.
The check valves are pretty close tolerance and have been known to "gunk up". The valves are common and most parts stores have them for a few bucks.
If the problem persists after installation of a new air compressor I would suggest replacing the check valve - it could be that the valve is plugged up and the compressor is choking due to high pressure on the outlet side -
in other words, with the back pressure (check valve) plugged off, the compressor is discharging against a closed system.
Even in normal operation these compressors draw a fairly high amperage load - and the wire going to them is marginal at best (10 guage originally on my 345 - and it is a LONG way from the front breaker to the compressor at the back) - just a slight increase in the "normal" amp load could possibly cause the compressor feed wire to heat up, increase resistance, and attempt to draw even more amps - just a thought.
Don't forget there is a separate "blow down valve" that relieves pressure from the compressor discharge when the compressor is not running - and is activated (closes the blowdown valve) when the compressor is running. This solenoid could also have a short in it, causing your high amperage condition.
Luck.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-07-2005, 08:42 AM   #26
1976 31' Sovereign
Images: 8
You're killing me....Just when I was sure I was done, I'll have to have him check it out but I'd rather know now than fight it later. Thanks for the input....also, where is this selenoid you're referring to? I may have to walk him through it over the phone to check it out. thanks,
Josh
Old 02-07-2005, 09:09 AM   #27
87MH's Avatar
1978 31' Sovereign
Images: 292
You're killing me........also, where is this selenoid you're referring to?
Here is a pic of my system - your's may be a bit different -
The "Bleed down Solenoid" is mounted on the accessory rack, in the picture, just to the right of the pressure control (on - off) switch -
Name:	Air Compressor &  Lines.JPG
Dennis
WBCCI # 1113
AirForums #1737
Old 02-11-2005, 05:39 AM   #28
1976 31' Sovereign
Images: 8
More Updated....or up to date
87MH,
OK man...you're good. He received a quote to replace the pump and they Airstream told him a little over $600 and I told him about the check valve. So, with the price of the pump in hand, it remotivated him to verify the check valve....and....it was bad. So, he spent $15.00 for the new valve and put it all back in. They Airstream is doing great and he's very happy.
He wanted me to tell everyone on here thanks and how much he appreicates all the help. I bet he wishes he used his computer more and would upgrade from dial up now!
He just needs to fix his speedometer and he'll be 100% back up and running. Thanks again guys. I'm going to keep this thread bookmarked and I'll post any updates that come along. I can't offer anyone any advice but I don't want to just "eat and run". I feel like we've bonded... ha
THANKS!!!!!!
Josh
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
