Old 02-19-2008, 06:19 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Radio in the glove compartment!!
This is not important but it’s frustrating. I bought my 2003 AS LY 30” (Gas) used. I couldn’t believe this but the radio was in the glove compartment. Yes-I did say glove compartment. I understand the previous DW could not reach it so had it moved by a audio techie. Now I want to move it back to the correct location in the dash. Problem is I can’t see anyway possible to brace it from behind, above, or below. With the rear view monitor above the spot where the radio should be, and not knowing how it was installed from the factory I can’t see how to brace it. Has anyone experienced radio removal? Thanks. Steve
spat61 is offline   Reply With Quote
Old 02-19-2008, 06:30 AM   #2
Naples , Florida
Howdy,
I don't know how your A/S was secured, but most of the large, high-end MoHos that I work in use the dash plate ALONE to secure the radio. They have no bracing at the rear at all..................YMMV
lewster
Old 02-19-2008, 08:40 AM   #3
Alumatube's Avatar
1984 31' Airstream310
Central , Ohio
I have seen a lot of car stereo installations that use what looks like a piece of rigid pipe strap (metal strip with holes punched in it) to secure the back of the stereo. It attaches to the back of the stereo and it long enough to attach the other end to the firewall or other structural component. I have no idea if there would be enough room for you to be able to get behind the stereo to do this in your moho, sorry! It would be very difficult (if not impossible) in our 310 Classic.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 02-22-2008, 06:28 PM   #4
On our 1984 310 motorhome there was just enough room to fit the radio, the back actually rests against some of the air ducts under the dash. So basically its fixed firmly in place.
1975 24' Argosy Motor Home
Old 02-23-2008, 06:06 AM   #5
jzelle's Avatar
2006 28' Safari SE
Halifax , Nova Scotia, CANADA
I installed a radio in the glove compartment of one of my cars some years ago - It was the only way to prevent theft. Had three radios stolen, the last one only 2 weeks after a new replacement.Installing in the glove compartment put an end to that.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 02-25-2008, 01:47 PM   #6
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
My 2000 LY 350 Gas has the radio in the dash,
No other brackets, just sits there , now the dash is cracked
If you install it in the dash make sure you brace it!!!
myfirstrv is offline   Reply With Quote
Old 02-25-2008, 05:05 PM   #7
spat61's Avatar
Thanks everyone. MYFIRSTRV has the same problem I now have, that is - a cracked dash panel and that's my frustration. Another member suggested making a dash panel with aluminum, then glue the original to it. I call Airstream for a new panel. Cost is $155.00 plus shipping. Thanks to everyone for the great response.
Steve
Old 02-25-2008, 07:26 PM   #8
myfirstrv's Avatar
Vermilion , Ohio
Steve,
That was my post on a different thread,
So I'm having the aluminum programed and cut on a CNC
My dash panel has two bends in it I plan on punching two holes one at the top and one at the bottom of each of these bend locations as a guild to make this crease
I guess I shall see how good my measurements are when I get it back from the shop.
When you called the mother ship did that panel come pre cut with the cut outs already there ?
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
toggle switch in glove box mlmarch Classic Motorhomes 7 02-20-2007 07:20 AM
XM Radio cosmotini Computers, Internet & Satellite 13 03-31-2006 04:06 PM
XM Radio for me! SilverToy Audio, Video & TV 17 06-07-2005 06:47 AM
Radio won't work Astrodokk General Motorhome Topics 2 05-25-2005 02:05 PM
