Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 01-01-2008, 12:03 PM   #1
GSTAG
GSTAG's Avatar
Profile:
radiator hoses
HELP!! I am unable to find replacement hoses for my 1981 motorhome. The GM part nos. are 6259953 &343414. Everyone says they are discontinued. Does anyone have any ideas?
GSTAG is offline   Reply With Quote
Old 01-01-2008, 12:23 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Hi, and welcome to the forums.
Your 81 should be a P30 chassis, just wander into your local Napa with the hoses you need, and tell them you are looking for hoses for a bread truck, with whichever engine yours has (probably a 454cid/7.4L).
There are other things you should do for the cooling system while you have it apart, like a thermostat and gasket. You can get those parts the same way.
Good luck.
Change is inevitable, except from a vending machine
AIR#2611
Old 05-07-2008, 09:38 AM   #3
labarquera1
Profile:  Miami Beach , Florida
Radiator hoses
Greetings friends!
I'm currently replacing hoses / belts, etc. on our 75 Argosy 20 ft 350 engine. Tracking down parts is more work than the actual installation! So now you can milk me for my information.
I had good luck at AutoZone, who lists their parts choices very well in their computer. No "universal flex hose" here, they had the exact hoses. Napa had only the top hose, and it was a flex. I suggest Motorad "fail-safe" thermostat while you are at it...when the engine overheats, it locks in the open position, sparing potential engine and transmission damage. $13 at AutoZone. Suggest changing water pump , alternator, and fan clutch while you are up there. And belts, hoses, radiator cap, and vacuum hoses as well . Prior to doing anything, use the $5.99 Prestone Super Cleaner in your cooling system to douche out all the sludge and scale. Replace antifreeze with extended life stuff.
I used my little Casio camera to make mini videos of where everything goes so that I could put everything back together correctly.
labarquera1 is offline   Reply With Quote
Old 05-10-2008, 03:06 AM   #4
Boom Sounds
Airstream 250 MH
Boom Sounds's Avatar
Profile:  London , UK
Hose replacement
Great info - any chance you might post of host those videos here on on ClassicMotorhomes cause I'm sure someone would find them useful
thanks
Nick
Boom Sounds is offline   Reply With Quote
Dash a/c vacuum hoses bkahler Mechanics Corner - Engines, Transmission & More... 2 06-23-2007 10:26 PM
LP hoses ipso_facto LP Gas, Piping, Tanks & Regulators 19 01-26-2006 11:47 AM
Radiator Hoses for 454 fwiz Mechanics Corner - Engines, Transmission & More... 8 07-26-2005 05:29 PM
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 6 12-24-2004 08:44 AM
Water hoses ALANSD Mechanics Corner - Engines, Transmission & More... 8 01-26-2003 10:46 AM
