Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 12-22-2017, 06:48 AM   #21
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by bkahler View Post
Not yet. With my Argosy being stored and worked on inside it has not been a pressing issue to apply the Vulkem.
However I did have Ernie seal Peanut's windshield with Vulkem and it appears to have stopped the leaks coming from that area. I had him pry the gasket away from the glass and aluminum and the sealant was applied in the gap and then the gasket was laid back into place. The excess was then wiped up. He did use masking tape around the edges to help contain the mess.
Since the sealant was applied I haven't noticed any leaks coming from the windshield.
That's good news. The most important thing, in my opinion, is having a clean/dust free surface. Dust tends to collect under the gaskets. I used compressed air and a damp rag with lacquer thinner to remove any oily residue.
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 12-22-2017, 06:59 AM   #22
I know Ernie didn't use compressed air but he did clean with lacquer thinner. I know Peanut's windshields leaked for a long time because the cockpit floors were mostly pulp
1975 24' Argosy Motor Home
Old 01-08-2018, 12:23 AM   #23
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
https://gbr.sika.com/dms/getdocument..._uk_v01-08.pdf
Boom Sounds is offline   Reply With Quote
Old 01-08-2018, 05:22 AM   #24
Airstream Driver
1994 30' Excella
Images: 49
Originally Posted by Boom Sounds View Post
I checked again, but it seems the Move-it has been replaced with a new product and is no longer available in the US:
Sikaflex® P2G PLUS
https://usa.sika.com/en/group/News/2...-Launches.html
I found it on Amazon
https://www.amazon.com/Urethane-Adhe...C2%AE+P2G+PLUS
AIR #13
Old 01-08-2018, 08:05 AM   #25
Sikaflex® P2G PLUS
So is this what's being recommended now for sealing windshields?
Old 01-08-2018, 04:43 PM   #26
Airstream Driver
1994 30' Excella
Images: 49
Seems like it, problem is that I saw the Move-it stuff perform for 11 years plus, but have no experience with this new line.
AIR #13
Old 01-09-2018, 05:13 AM   #27
I hate to say it but this new stuff sounds like the stuff we tried after the Move-it disappeared. It lasted about a year and then pealed right off. I think I'll stick with the black Vulkem that you sent me.
Old 01-09-2018, 05:25 AM   #28
Airstream Driver
1994 30' Excella
Images: 49
I tend to agree, Brad. Vulkem is a proven sealant/adhesive, will stick to just about everything, except the clear coat they put on replacement panels.
Well, lets say it sticks just fine and seals, but does not have the same adhesive properties you get when applying vulkem to unsealed aluminum.
If the clear coat is lightly scuffed with sandpaper or steelwool, it will stick like thunder.
Due to the nature of my business (dealing with coatings and a large variety of surfaces), I am a test sample freak. I am often shocked and amazed what you find out after something is in service for a year or more.
AIR #13
Old 01-09-2018, 05:48 AM   #29
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I found an review of the P2G that indicated you really had to thoroughly clean and then use the primer (comes in a container with a swab attached to the inner side of the lid) to stand any chance of it adhering to the seal side as it is actually designed to stick the glass to bodywork not seal to body work.
martin300662 is offline   Reply With Quote
Old 01-09-2018, 02:45 PM   #30
This is the product which is available on the UK market which seems to be for buses/trucks etc and bonds and seals.
SikaTack®-MOVE Transportation
https://www.sika.com/en/solutions_pr...portation.html
Glass replacement adhesive for buses, coaches, trains and special vehicles.
SikaTack® MOVE Transportation is suitable for direct glazing and gap filling applications in one work-step in the Bus, Truck and Rail glass replacement business.
CHARACTERISTICS AND ADVANTAGES
Black-primerless
One-component polyurethane
Cold applied
Shortest Safe Drive-Away Time
Suitable for bonding and gap filling
Excellent application and non-sag properties
Optimal open time for large and heavy windscreens
Good UV- and chemical resistant
Prevents contact corrosion in aluminium bodied vehicles
Solvent-free
COLOUR
Black
PACKAGING
Old 01-09-2018, 04:43 PM   #31
We used Vulkem 116 in black on Peanut. So far the leaks appear to have been stopped. If it holds up through this winter then I don't think I'll worry to much about it after that.
Definitely no fun doing the job twice!
Old 01-10-2018, 04:25 AM   #32
Brad - can you use this stuff as a sealant around any potential weak spots?
Old 01-10-2018, 04:57 AM   #33
When I'm assembling things that could potentially be the cause of leaks the sealant I use the most is Tempro 635. It's not grainy and gritty like Vulkem 116.
When Airstream was building these things the they liberally applied the sealant and that's pretty much what I do.
Old 01-10-2018, 05:29 AM   #34
Airstream Driver
1994 30' Excella
Images: 49
I like the tempro 635 for sealing around the aluminum windows for the reasons Brad mentioned. But I have only seen it in Gray, the vulkem 616 comes in a variety of colors, incl gray, black and aluminum
AIR #13
Old 01-11-2018, 05:09 AM   #35
Vintage Trailer Supply lists it in white and gray. I've used nothing but gray myself.
Old 01-11-2018, 05:23 AM   #36
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Whatever you use, watch out for streaking on the glass.
I used butyl tape as a emergency leak repair one time and when the rain hit it, I had black streaks all the way down the glass and it was very hard to remove. I used the 3M 08693 urethane sealer last time and no more streaks.
WayneG is offline   Reply With Quote
Old 01-12-2018, 10:22 PM   #37
mattpalmeris's Avatar
nanaimo , British Columbia
Sealant
I recently picked this up from Amazon but have yet to try it out but I think it has many of the same properties the old stika product had. My motohome is plagued by front windshield leaks and the PO has smeared black silicone all over the top weatherstrip. My plan is to remove the lock strip and run a bead of the 3m glazing compound between the body and weatherstrip all the way around.
Question on other peoples rigs, do you have a bead of urethane or other sealant along the top of the windshield or do you just let the rubber do its job?
https://www.amazon.ca/3M-08509-Beddi.../dp/B000PF13JW
mattpalmeris is offline   Reply With Quote
Old 01-14-2018, 08:42 AM   #38
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Will this 3m compound react with the aluminum body, read horror stories on the Forum about different chalking reacting with aluminum causing pitting and corrosion. I need something to seal my windshield also. Let us know how it works.
cole3444 is offline   Reply With Quote
Old 01-15-2018, 11:35 PM   #39
The Sika product I posted specifically says it avoids contact corrosion in aluminium bodied vehicles
