Old 06-12-2018, 01:16 PM   #1
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Project of the day: AC Power Protection
Most of the places I hookup to shore power, I either know and trust the source or I have wired it in myself, and mostly trust it
This year I will be trying out campground shore power for the first time so I figured it is time for some safe campground sex I mean power
I looked at the inline pigtail devices but they seemed either too cheap or too expensive so I picked up one of these:
Progressive Industries EMS-HW30C Portable Electrical Management System - 30 Amp
It has the remote display and seems to protect you from almost anything but sex!
Normally it is installed by cutting the power cord and splicing it in, but I decided to put it after the generator/shore power relay, that will protect my stuff from both sources.
When I powered it up by the generator I found out my AC volts were 135 so the power was cut off. I fixed that problem by slowing down the generator RPM's and now it is in range to not trip out.
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 06-12-2018, 01:50 PM   #2
2007 22' International CCD
Thanks for the pictures..I'm planning a similar installation, and did not have a good idea if what the remote looked like. Looks like I need to build a bezel to flush mount the remote to keep DW happy...I'm not allowed to surface mount any boxes.
My normal and usual "engineering OCD" loves the labels on all the boxes!
rmkrum is online now   Reply With Quote
Old 06-13-2018, 03:37 AM   #3
WayneG's Avatar
Scotia , New York
Yes, recently I get very carried away with labels and documenting everything.
My memory is not what it use to be, so I need to write it down for me or the next owner to figure out how I did that.
Here is my wiring diagram of my AC circuits. It has quite a few additions and modifications from the original.
Also, my remote is held on with VHB tape, so no holes, but still a less than perfect look.
Old 06-13-2018, 05:44 AM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Nice installation. I'm a big fan of the Progressive EMS, and hardwired is definitely the way to go. Does yours buzz? You have a pretty tight turn on that wire, and mine will buzz if the wires aren't fairly straight going in/out of the box. Not sure why.
TheGreatleys is offline   Reply With Quote
Old 06-13-2018, 07:01 AM   #5
WayneG's Avatar
Scotia , New York
I did notice a buzz when I turned it on one time, but other times it has been quiet. It may be just how well the relay pulls in?
I will keep a lookout for that in the future and see if I can find the source.
Old 06-13-2018, 07:49 AM   #6
Oh crap.....one more thing to add to my list!!
Old 06-13-2018, 08:08 AM   #7
WayneG's Avatar
Scotia , New York
Just think what it would cost to buy all this "necessary stuff" all at once, and it does not feel so bad a little at a time
Old 06-13-2018, 10:54 AM   #8
Now THAT I understand I've been buying bits and pieces for years and the way it's looking I will probably be buying bits and pieces for years to come
Old 06-13-2018, 04:12 PM   #9
1985 31' Excella
st. Paul , mn
At a park I was at , one of the units that hang from the shore power post , was in the dumpster .
Well I do electronics repair and worst case , recycling .
It had filled up with water - guessing rain water , looked it up on the internet & found they are warranted for that /
Cleaned out , tested & repaired - a good $400 ++ find , of course some abilities to repair .
Another " happy camper "
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 06-13-2018, 04:22 PM   #10
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
When I installed a Progressive Industries EMS-HW30C in my Interstate I also mounted the list of error codes near the remote display, which I've found helpful. See photo below. That labeling on the remote bypass switch is also nice.
- - Mike
Old 06-13-2018, 04:38 PM   #11
WayneG's Avatar
Scotia , New York
That sounds like a good idea, much easier than finding the list on the main electronics box cover! Especially since mine is at floor level.
Old 06-14-2018, 08:43 AM   #12
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
I'm a big fan of the Progressive EMS, and hardwired is definitely the way to go. . .
So if you get a Fault, check the power post, all is fine, contact Progressive and they say, "oops, sounds like a Warranty issue", the hardwired unit uninstall, wait for new, re-install drill will disable your power grid? I like my Power post model.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 06-14-2018, 09:01 AM   #13
1974 27' Overlander
It seems like that would be a fairly rare occurrence. Is that something you personally experienced?
You can get a bypass switch for the hardwired model if you're concerned about failures. I believe the remote model includes the bypass switch standard. Worst case scenario, removing the front cover and bypassing the unit manually is a 10 minute job, tops.
I like my harwired design because it's hard to steal, impossible to forget, I don't have to carry it, and it takes a moment to bypass it, which gives me extra time to consider whether that's actually a good idea.
There's certainly nothing wrong with getting a portable model if that's what works for you. But I don't think the possibility of a failure is a compelling reason not to go hardwired.
Old 06-14-2018, 09:24 AM   #14
Obviously-NOT
Kalispell , Montana
Didn't know about the built in bypass option. All good.
Education Please? Ref. Surge Protection & Power Boosting AIRHEDS Generators & Solar Power 1 06-28-2016 12:22 PM
Power surge protection Mifair On The Road... 9 04-04-2012 09:42 PM
Electrical Power Protection geojpaige Electrical - Systems, Generators, Batteries & Solar 4 07-26-2010 03:54 PM
bad day airstreaming beats good day a power company part 2 john hd Off Topic Forum 9 02-13-2004 08:12 AM
bad day airstreaming beats good day at power company! john hd Off Topic Forum 5 01-29-2004 04:04 PM
