Old 09-02-2007, 06:01 PM   #1
1987 34' Limited
1987 34.5' Airstream 345
Tyler , Texas
Problems Problems Problems
Hi! As I was driving thru Dallas on I-20 this morning my 345 shut down as if I had turned a switch off. Lights work... no dash gauges ..no nothing...nursed it to the shoulder and afer 5 hrs a wrecker contacted by Good Sam arrived and towed the AS to a Chevy dealership. Having driven more than my share of miles I have never had this happen before, although there are always surprises on the AS.
Any words of encouragement or maybe a quick fix?
Pete
pjude is offline   Reply With Quote
Old 09-02-2007, 06:04 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Pete
Fusible Link.
Ignition Switch.
Fuse.
Old 09-02-2007, 06:13 PM   #3
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Pete, I'd say that if you were near San Angelo, you'd be welcome to crash in our Sovereign for the night.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-02-2007, 06:21 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Hang in there. Owning an Airstream can sometimes be challenging. I would also vote for the ignition fuse.
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 09-02-2007, 06:33 PM   #5
richinny's Avatar
2011 34' Classic
since so much is not working i'd guess it is between the battery and main fuse panel. from what i've read here i'd say it is a fusible link. check behind the alternator and at the starter. use a test light as sometimes they melt without melting the insulation.
Ricky
Old 09-03-2007, 02:50 AM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Sorry to hear of our problems...ugh!...just what none of us want on the road (or any other time)... I'm not much help on the causes or fixes of your troubles, but I can hope for your good luck and offer moral support. Keep breathing and it will all get sorted out...and you'll be back on the road soon...
TB
Old 09-03-2007, 07:25 AM   #7
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I am very sorry to hear about your troubles. Owning a classic AS motor home you will become accustomed to surprises. What's with Good Sam and 5 hours! They send me a letter a day stating their tow truck will be there instantly! Not only that but a special tow truck just for motor homes! Sounds like the Dallas area never read the advertisement.
There are several causes for your problem. I would first check all fuses, second the fusible links. Third, is your charging system, how much juice do you have in your starting battery? Do you have power on the coach side? There is a small resistor wire that runs from your ignition back to the relay switch between the starting and coach batteries. If this wire breaks you will loose all power to the ignition switch. The wire is tan on my coach. I am attaching a picture of the location of the fusible links for you, thanks to Peter H. This is on his coach not my diesel.
Good luck to you.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Air bag problems ... help! Mike Leary Off Topic Forum 3 03-18-2007 02:28 PM
Tab Problems azflycaster Forum Admin, News and Member Account Info 11 02-09-2007 11:37 AM
A few problems w/ my CCD PunkZTT 2002 - 2005 International 10 03-30-2006 11:38 AM
AC Problems PhiDor Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-11-2006 08:11 PM
Pet problems? sjptak Our Community 29 06-22-2003 12:36 PM
