Old 09-12-2015, 10:16 AM   #1
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Price
Hello everyone
in recent days, I started to renovate the kitchen furniture, and seeing the construction, my god.
then I asked myself, (the RV Argosy I think in the 70s. It was not cheap), sorry for the criticism, but as they could (I do not know if everyone is like or just mine armed them with such a low cost) rv expensive as performing the economic kitchen cabinet in an expensive rV?
anyone know how much was the price of that time Argosy? the truth that I'm interested to know
Thank you
Herman
german6563 is offline   Reply With Quote
Old 09-12-2015, 12:00 PM   #2
Originally Posted by german6563 View Post
Hello everyone
Thank you
Herman
What size Argosy?
Old 09-12-2015, 12:01 PM   #3
Hello everyone
Thank you
Herman
Trailer or Motorhome?
Old 09-13-2015, 03:18 AM   #4
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hi
sorry
Is Argosy motorhome 24
Old 09-13-2015, 04:07 AM   #5
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
This the spec and pricing list from 1975
martin300662 is offline   Reply With Quote
Old 09-13-2015, 05:24 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That'd be a little more than $75k today.
Old 09-13-2015, 06:40 AM   #7
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Hi Herman, to your point about the 'quality' of the construction, remember at the time the focus was on 'light-weight' (which means flimsy looking) construction to keep weight down. They would have thought it crazy to install cabinetry made from 5/8" or thicker timber. I would have to say they maybe correct as you will find yourself you have to put in considerable effort in getting the old stuff out!
Old 09-13-2015, 11:51 AM   #8
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hello,
the price was anything but economic,
Martin, I can understand wanting to reduce weight, but I believe that cooperation could be elsewhere in the RV reduce weight and keep it in the kitchen for example.
and throw everything out and try to change with thicker walls and shelves, the front I have to leave the original.
Herman
Old 09-13-2015, 12:37 PM   #9
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Hello,
Herman
To give an example Herman, to rebuild the beds, wetroom and kitchen in our 20ft Argosy we used 10 8'x4' sheets of 3/4" maple ply (coated on one side with white laminate), each sheet weighed around 75lb, so we added 750lb of weight. If we had used a frame and ply construction, we would have only used about 120lb in 1/8" ply plus the weight of the timber for the carcass. It would be very difficult to gain that weight back elsewhere; we can do it today using modern materials but they weren't around in the 1970's.
Old 09-14-2015, 04:06 PM   #10
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'm with Martin on this one.
I have redone every cabinet in my 310, but to save as much weight as I can and yet have a better product has meant I had to come up with different methods of cabinetmaking.
I used solid pine as a face frame and then attached gables in behind. I only attached enough of a gable to mount my slides and that was all, no backs or in most cases, no bottoms or tops of the carcasses, just the front face frame with a few gables maybe 11" deep or so. Because I reduced as much material as I could I was able to use bottom mounted soft close slides, build the drawers bigger and more of them.
http://www.airforums.com/forums/f311...s-97332-4.html
If you go back further in the thread you will see I even kept the old gables as they were aluminum with paper board in-between and I couldn't replace them with anything lighter.
The general rule goes like this. For every 100lbs of weight you add to your vehicle you must add 10hp to maintain the same performance. However the more weight you add the more it affects your handling, braking and wear and tear.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Price Paid to Price Asked BillWill Trailer Values 46 08-11-2009 05:03 PM
Sticker Price Tag kzener40 Airstream Motorhome Forums 6 01-08-2006 02:10 PM
Price guide for site? ViewRVs General Motorhome Topics 7 01-04-2003 11:06 PM
Gas price watch 83Excella Link Archive 1 07-09-2002 11:15 PM
Great Flooring Price melprice Floor Finishes 0 07-08-2002 08:48 PM
