Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 12-18-2003, 10:41 AM   #1
DouglasPowel
Profile:
Post Plastic underbelly parts for classic motorhome
Need a replacement curb side front plastic "underbelly" part to replace a broken one on a 80's vintage classic motorhome.
DouglasPowel is offline   Reply With Quote
Old 12-19-2003, 06:13 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Banana wrap? The curved part that wraps from the lower body trim around underneath? If so the ones for the trailers are available from Airstream, I would try there or a salvage yard.
John
74Argosy24MH is offline   Reply With Quote
Old 12-31-2003, 07:54 AM   #3
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Can you post a picture of the spot? That might help folks better identify the part you need.
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 02-21-2004, 09:46 PM   #4
IPM
1981 28' excella motorhom
IPM's Avatar
Profile:  Sutherland , Virginia
It's possible to repair those parts
I've done it. Get a cheap plastic welder from harbor freight. Melt fuse the breaks together. Use plastic caps from spray paint cans and similar to reinforce, fill in, level. Melt in or onto where needed. Use hand grinder to smooth. Then switch to standard body fillers. Follow standard body panel finishing from there. For classic paint match, tool box grey from sears.
WBCCI #7006
IPM is offline   Reply With Quote
Old 02-28-2004, 05:43 PM   #5
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
was on inland site. andy has the front pieces for the classic motor homes in fiberglass. not cheap but if you need them they are cheap.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB
wb13798 is offline   Reply With Quote
