PA Winterizing Procedure
Hello, all! We are about to winterize our new (to us) 86 345, and have some questions so we do it right! We will drain the system without blowing air through, then add 8 gallons of RV antifreeze (pink) to the tank, and pump it through all of the faucets, etc., plus (non-bypassable) water heater and ice maker, after draining whatever we can. Is this the best recommendation, to put this substance in all of the lines, as we don't have bypasses installed? It will all just flush out in the spring, and incidentally be protected from algae growth (the bottle says)? Help!
