Old 01-22-2010, 04:25 PM   #1
345bill's Avatar
Las Vegas , Nevada
P32 Chassis
I read here often about the P32 chassis. I'm curious to know which AS/MH's have them. Were they used on specific models, options, years??
Thanks.
345bill is offline   Reply With Quote
Old 01-31-2010, 10:06 AM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
345Bill, I Google Work Horse P32 and was surprised. From what I read all RV chassis from GM were P32 which would include AS, and that P30 is more of a model reference. At that web site Barth MH forum listed there, has alot to say about the diffferences between P30 and P32.
So if I'am under standing it right, all years AS MH are included and built on the P32 chassis.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-31-2010, 11:37 AM   #3
345bill's Avatar
Las Vegas , Nevada
Originally Posted by gloran View Post
345Bill, I Google Work Horse P32 and was surprised. At that web site Barth MH forum listed there, has alot to say about the diffferences between P30 and P32.
gloran- You're not alone in being surprised. Every time I think I have it half way understood I find something else that throws a curveball into my thoughts. I haven't had any problem when ordering parts for my 1990 345LE and I've always told the parts people it's a P30, which is what I was told when I originally purchased the MH.
So....I'm now kinda thinking most AS/Mh's are on a P32 and the 345's use the P30? (that thought could easily change)
Old 02-01-2010, 05:53 PM   #4
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
P30 seems to as mentioned be a catch all for the Chevy frame we all enjoy.
In fact the VIN is the key to parts. I had to get up from my easy chair to check the visor and in fact my 1987 28' FC is a P37.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 02-01-2010, 06:10 PM   #5
_
touched on just hours before this thread, perhaps u missed it?
http://www.airforums.com/forums/f310...tml#post797415
cheers
2air'
Old 02-12-2010, 12:19 AM   #6
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
As far as I am aware the MH came on a P32 chassis which was a MH version of the P30, there were several different wheelbase lengths, although much of the literature and service manuals refer only to the P30. I think that in some instances there were a very few parts which were MH specific rather than just plain old P30 parts...
Chuck - does this seem right to you?
Boom Sounds is offline   Reply With Quote
Old 02-12-2010, 11:21 AM   #7
Chuckles's Avatar
Iwerne Minster , Dorset. UK
OK! ....mmmm...... Yes! it's clear - well nearly.............. as mud!!!!
As usual... any model numbers, chassis numbers, production numbers, what ever you like, are not logical.
P-30 (P-300) is a series with various other models P-32,P-42, P37 etc referring to mods, updates different weights etc, it is quite lengthy but perhaps the following thread/discussion below will help - its not worth writing it all out again but the info in this article is very informative.
try it
P-30 vs. P-32 Chassis - Topic Barthmobile.com
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 02-12-2010, 01:16 PM   #8
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The P is for forward control, the 3 is a 1 ton weight series. Beyond that the mystery begins.
When I recently bought a center support bearing the book showed two different sizes. I knew from a recent discussion with a spring shop that the motor home chassis with 4 wheel disc brakes has larger diameter axle tubes than one that has drum brakes. So I said I need the larger bearing of the two. Naturally I took it back the next day to exchange for the small bearing.
I also own a 1979 5 series GM truck. The truck has a 3" drive shaft while the Moho has a 4" drive shaft. The differentials appear to be about the same size and both vehicles run 8x19.5 tires.
I think a lot of what they used was what their suppliers had shipped and was available for installation.
Cheers, Dan
Old 03-23-2011, 11:33 PM   #9
1990 36' Land Yacht
Dearborn Heights , Michigan
Someone said it earlier in here, the key is your VIN numbers (characters 5-6-7) P30 is a chassis only, P32 is designated as forward control chassis, P37 (mine) is designated as a motor home chassis. BTW the 4th character denotes the gvwr-brake system (K=14000-16000lbs, hyd. brakes) and the 8th character is the engine (N=7.4L tbi) these codes are from a '88-90 repair manual and may vary slightly in different years but i believe the position in the VIN number is the same.
"Silver Lining"
MrFixit is offline   Reply With Quote
Old 03-23-2011, 11:37 PM   #10
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
The 370 MH is built on a Gillig chassis with a Ford 460 drivetrain. It's the only AS classic MH I know of not on a P-30.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 03-24-2011, 06:34 PM   #11
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Thanks.
I'm afraid I cannot tell you exactly which ones have the P32, however, I found this handy little table on page 7 of a "Workhorse Gas Motor Home Chassis Guide" that I downloaded from the internet. It covers years '99 and newer. Just match your VIN with the corresponding position #'s at the top of the page. Our 2005 AS LYG 30 SO has a P32. Hope this helps.
Maybe Workhorse has similar tables for older P series chassis as well.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Workhorse P32 Ignition Switch kmamedia Mechanics Corner - Engines, Transmission & More... 3 12-02-2008 01:03 PM
Freightliner Chassis Torpedo Family General Motorhome Topics 0 05-19-2007 06:13 AM
Chassis Wiring tn2 General Motorhome Topics 5 05-07-2007 04:47 PM
MH on a Toyota chassis? ViewRVs Airstream Motorhome Forums 11 07-13-2003 01:03 PM
chassis paint john hd Off Topic Forum 2 10-30-2002 03:36 PM
