Old 04-08-2010, 08:07 AM   #1
projector's Avatar
1972 23' Safari
NSB , Florida
P30 airbag springs worth it?
I local suggested I add rear air bags so I can lift the back as needed. It came up because the bottom of the hitch receiver drags when backing out of the driveway. This is with out the hitch extion, basket and boat bechind it.
What are your opinions on these and what else can they do for me?
thnaks
projector is offline   Reply With Quote
Old 04-08-2010, 08:22 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
that makes a lot of sense. Being able to adjust them would be a great asset when you are faced with parking lots also that have that low dip, or weird angles.
What amount of lift would you get?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-08-2010, 10:34 AM   #3
2007 25' Safari SS SE
Vaporville , Confusion
We had a similar problem. Are you sure that you dont just need a shorter shank? Replacing the Shank (we needed to anyway) fixed the dragging problem as a side effect. I havent seen these airbags before, they sound interesting enough. In my case it was a simple replacement shank that solved this problem.
TropicGuy is offline   Reply With Quote
Old 04-08-2010, 11:55 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Mine was also assisted by using a heavier shock in the rear, but it still could drag on entry and exits. Also front steering damper and shocks were upgraded.
AIR #005
retired!
Old 04-08-2010, 03:45 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I thought I would have trouble with the long overhang so I mounted a solid steel wheel at low point of hitch, just behind bumper, and did hear it scrape as we left after gassing up at too small a station, luckly saw angle of exit and decided to do it diagonally, probably would have hung up if I didn't. Solution for future reference is a couple of cents cheaper gas not worth taking chance, stick to large stations. I would do the more expensive bags if it was my driveway causing problem or fix driveway.;-)
Old 04-12-2010, 04:14 PM   #6
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
2000
LY 350 GAS
Installed AIR LIFT 5000 Air springs last fall
Got the Compressore with the remote can fill or dump with a remote inside the bus or out side -- NICE
Love them
myfirstrv is offline   Reply With Quote
Airbag replacement Nick Danger Mechanics Corner - Engines, Transmission & More... 100 03-16-2017 05:39 PM
Airbag armed or not thecatsandi On The Road... 5 03-02-2009 06:58 PM
airbag suspension question airstreamers Off Topic Forum 2 03-28-2007 03:02 PM
airbag suspension nevisstudio Axles 2 10-29-2003 08:48 PM
Rear Airbag Donald B Graves Airstream Motorhome Forums 9 03-15-2003 08:03 AM
