Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 01-26-2005, 02:34 PM   #1
Thumbs up onan generator
how do i replace starter in onan 28 ft 82 motor hane itried starting and it engaged but wouldnt start. it fried the battery. idisconected. ithought it was astarter problem. any ideas would be appreciated. :confused:
Bozair is offline   Reply With Quote
Old 01-26-2005, 05:12 PM   #2
. , At Large
Originally Posted by Bozair
how do i replace starter in onan 28 ft 82 motor home?
Umm, If I remember correctly, the generator itself is turned into a starter motor to crank the engine by applying 12v to the low voltge terminals.
Old 01-26-2005, 07:30 PM   #3
LOST , Hawaii
Some did use the windings, others had starters so it will depend on the model. If you have a 4KW (BGE) or 6.5KW (NHE) Emerald this is the manual page. It is on the opposite side of the engine from the oil filter.
John
Old 01-27-2005, 05:37 AM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
No "Starter" on the '87 345 (Onan 6.5 - NHP)
Bozair - Welcome to the Forums -
Lots of communal knowledge and experience within the "hive" of the Forum.
The 1986 6.5 McGraw Edison Onan Model 6.5NH-3CR/1600 4P that the '87 345 came equipped with utilizes the 12 volt windings as the starter.
The "weak link" of the starting system on mine was the "relay modules" -
The 1" black cubes are found on many Ford products - generic units are much cheaper than Onan (Onan doesn't even bother to rename the solenoids) - generic run about 5 bucks apiece - going by memory, but I think there are 4 in the "Control Panel" of the 6.5 KW. The starting system also utilizes a conventional high amp "starting solenoid" (again, when I go into a parts house (NAPA, O'Reilly's, Auto Zone, etc.) I just say it came off of a "Ford").
- Sometimes it's best to just not add confusion to the purchase -
I see from your Public Profile page that you also have a 1988 bronco II.
From that I assume you already are on a first name basis with the manager and all of the counter help at your closest parts store - if not, with the '82 28' you soon will be.
The destination is well worth the journey - during times of tribulation (and there WILL be times of weeping, woe, and gnashing of teeth) you will always find a sympathetic ear here on the Forum.
Remember, there are many ways to accomplish the same mission, and each one of these old MoHos seem to be unique - what may be one way on my unit could well be another way on yours. Factor in 20 plus years of owner "fiddling" and street corner "service station" repairs, and you may well find major deviations of systems from unit to unit.
You might find these links helpful,
http://www.airforums.com/forum...ight=generator ,
Again, welcome, and good 'streamin'.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-27-2005, 06:02 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Why are you thinking it is the starter? Is there nothing happening when you push the button inside the coach...if so have you tried the start button on the gen itself?
Is it not cranking at all?
Is there power in the battery? Are the cables from the battery tightened .
Just a few other things to check.
Mine is an 82 280 also.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-27-2005, 06:25 PM   #6
. , At Large
If you are a masochist, I think that model has a pulley for a rope on the opposite end of the generator. Wrap a rope around it, and give it a pull. If it starts, you may be able to find the problem by "reverse engineering".
Old 01-27-2005, 07:34 PM   #7
LOST , Hawaii
I would rather go to Gilligan's island and pedal his bicycle.
John
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
